Where can I purchase the replacement belt ST4000 Wheel Drive formerly Part # D169 for the Autohelm 4000 wheel drive.The Raymarine Product # 36014 is out of stock.
Try this pdf manual. Its for the latest model but I also have an ST4000 and the instalation looks pretty much the same. http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=88&PRODUCT=4176
CLUTCH LEVER PIN BROKEN ,CLUCH LEVER OUT OF POSITION
BELT TENSION ADJUSTMENT WRONG (REMOVE SMALL COVER PLATE (+- 10mm Dia)ON REAR OF BACKPLATE ,LOOSE SPECIAL NUT ADJUST WITH ALLEN ,TORQUE NUT,PUT COVER BACK
GLUE THE SMALL POSTS EXACTLY IN PLACE AS THEY BROKE OFF ,DRILL A HOLE VERTICALLY THROUGH THE POSTS ,SAME SIZE AS HOLE IN THE SS WHASHER, (HOLE OF THE SCREWS)ALL THE WAY THROUGH THE BACKPLATE ,INSTALL A STAILLESS SCREW WITH HEAD ON THE REAR OF THE BACKPLATE AND NUT ON THE WASHER SIDE TRIM TO EXACT LENGHT USE LOCKTITE FOR NUT.
