Western Digital Caviar WD400BB 40 GB Hard Drive Logo
Posted on Aug 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do set the jumpers on the HD to slave ? thanks
Brian Sullivan
Level 3:
  • Western Digital Master 27,725 Answers
  • Posted on Aug 29, 2010
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5666157
Points
79191
You can find the jumper settings printed on the top of western digital caviar hard drives
slave setting with the hard drive end jumpers facing you is 2nd from the right or 4th from the right
good luck
5 Related Answers
Anonymous
  • Posted on Jan 19, 2008
SOURCE: Jumper Settings
another place to look is on the circuit board where the jumpers are connected you'll see : MS, CS, CAB, a space and TXD.
Cheers
Beni S-P
arben pllana
  • 1006 Answers
  • Posted on Mar 24, 2008
SOURCE: jumper settings
Here you have MANUAL'S
Anonymous
  • 143 Answers
  • Posted on May 18, 2008
SOURCE: Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Templarius
Davor Krstevski
  • 86 Answers
  • Posted on May 26, 2008
SOURCE: jumper settings for maxtor
http://www.tacktech.com/display.cfm?ttid=379
Go there and enjoy dude ....
mbase213
Mark Taylor
  • 728 Answers
  • Posted on Mar 28, 2009
SOURCE: HD Maxtor model 91360Ua
Hi fkjedi,
Most Maxtor drives all use the same configuration, but HERE a link to explain and show you how to configure each drive. You can print it out and save this for future use.
Thanks
Please leave a rating based on this solution!
Mark
2helpful
2answers
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
I have an extra hard drive that I would like to add as a slave HD to my computer the one I want to be a slave is a MAXTOR model 32049H2. how do I set up the jumper?
moz-screenshot.pngI would guess that it is a diamond max driver, and therefore the jumper setting for slave should be no jumper at all. But in case I am mistaken, here are all the jumper setups for Maxtor drives, choose the one that looks like your setup and then choose the correct Slave setting:oss279.jpg
I have a maxtor H.D. model # 31024h1 , i cannot find the jumper settings to distinguish between master and slave
Typically, for older MAXTOR drives, put the jumper on the 2 pins closest to where the ribbon-cable connects, to set it to 'MASTER'.
Remove all the jumpers to set it to 'SLAVE'.
I need the jumper setting for mode 2l51536H
you don't give much info to go on- but if you are adding a second hd and have your os on the existing hd, then you should set your second on 'slave'. there should be a label on the hd showing you where to set the jumper for 'slave' mode. make sure it's connected to the same cable as the other hd. 0n the second connector!
they have their priorities!
good luck!
1helpful
Install old maxtor HD on newer pc, change it from mster to slave
From your own description Slave : Off therefore remove the jumpers
1helpful
Setting Maxtor HD as Slave.
Howdy,
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Chris,
Armor-IT
2answers
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
Thanks
proton
Jumper Settings
If you leave it at cable select the cable will set the drive to either master or slave depending on where it is on the cable, the first or second connector. Just make sure any other drive hooked up is set to cable select.
Your best option is to actually set each drive to master and slave. Each drive should show you where to put the jumper. Make sure you only have one master and slave though.
Which jumper to use? The one thats already on the HD...?
:D
Check out this page for more information on Cable Select:
http://www.pcguide.com/ref/hdd/if/ide/confCS-c.html
New (used) hard drive
Just remvoe the cd rom and then try to install your hard disk. if it is detected than it means there is a problem of setting master and slave in jumper.
So just check again your jumper settings and read the front side description of hard disk for jumper settings.
2answers
Cannot boot in Slave mode
i have never heared of any hardrive being able to boot when it is set as slave, as the master is always the 'C' drive from which windows looks for the master boot record. why, if you have only one hard drive is it set as slave?, it doesnt make sense. No hard drive will boot up if there is no jumper cap on it, as the motherboard needs to know which hd is master and has the o.s on it.
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
