You can download it from a website called driver guide. I have downloaded it and confirmed no viruses and to be the proper driver.
Click here for the proview 700p driver
if you need further assistance please let me know, Thanks-Midwest-tek
SOURCE: Need help: ProView 700P Silver LCD Monitor
Your ProView 700P Silver LCD Monitor does not need a driver. Windows see's it as a plug & play monitor. Suggest you have the monitor repaired or refurbished by a pro.
SOURCE: green led light flashing on 700p proview flat panel and no picture
You need to replace the power supply! I work with these all of the time, the most common problem with thes montiors is the Power supplies do no generate enough charge to power it up to display an image! If the Power supply does not work I would look into getting a new monitor because then it is truly involved! Bad inverter, or blown LCD. I speculate that if your not getting any video after trying the new cord. replace the monitor! Sorry!
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
SOURCE: my proview 700p has lines and picture jumps can
hi,
Your TFT screeen cable has been damaged now voltage going to the Lcd circute is not correct pls swap cables i mean get it changed .
Thats why there lines on the screeen and picture is not stable .
Good luck
