Hi, I have forgotten the username and password for the admin account in my windows xp.
and the logon is not the fast logon where you can see your username and password hints, its the type of user logon where you have to type the username,
I currently have access only to a limited account.
Please help me sir!
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Forgot Windows XP Password? Here is 3 methods you can have a try to bypass xp password:
1. Perform Windows xp password reset with an administrator account.
2. Use Windows Password reset disk.
3. Use Using windows password reset software. Such as Windows Password Recovery or Windows Password Key Professional
For more detail guide on how to do this, please feel free to read this post:
http://www.windowspasswordsrecovery.com/bypass-xp-password-in-safe-mode.htm
A free video solution
You can download a windows password reset tool on the internet. It can reset Windows login Passwords. You could get back into Windows just within few minutes. I recommend this site http://www.reset-windows-password.com
Well, if you forgot your login password in windows xp, you can use Windows Login Recovery to bypass Windows xp password. And here is guide for you:
1: Start Windows Login Recovery software, select Reset local account password for Windows 7/Vista/XP/2008/2003/2000, and then click Next.
2: Insert the CD/DVD or USB flash drive into the computer. Select CD/DVD or USB, click on Burn to start burning a password reset disk.
3: The password reset disk will be successfully burned automatically then. Then click Quit when finishing burning.
Then you can use the password reset disk to crack windows xp password. It works great. Hope it be helpful.
Lots of people may forget their login info which possibility can't be
ruled out. For most of people, like freshman, may reinstall the OS so
that all of the original files would be lost and all our works may go
up in smoke.
In fact, there are some convenience ways to help us to be far from that
nightmare, as long as you paste "windows password", "xp password",
"administrator password", "vista password", "windows xp password",
"forgot windows password", "windows administrator password", "windows
password recovery", "windows password reset", "windows password
unlocker", ect to google, there would be many related results. One of
the most reliable way is to take use of windows password unlocker which is a current windows tool for empty or reset windows password for PC users even computer freshman. With windows password unlocker, just a few steps, you can re-login your PC without any data loss.
1. Login to a computer that can link to Internet. Download Windows Password Unlocker 4.0 and decompress it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD.
2 Get out the newly created CD and insert it to the locked computer.
3 re-booted the locked computer and then followed the process of instructions. Just a few steps, the old password was removed
Create a password reset disk To create a password reset disk for your local user account,
follow these steps:
procedure requires one blank, formatted floppy
disk.
1.
Press CTRL+ALT+DELETE. The Windows
Security dialog box appears.
2.
Click Change Password. The Change
Password dialog box appears.
3.
In the Log on to box, click the local
computer--for example, click Computer (this
computer).
4.
Click Backup. The Forgotten Password
Wizard starts.
5.
On the Welcome to the Forgotten Password Wizard page, click
Next.
6.
Insert a blank, formatted disk in drive A, and then click
Next.
7.
In the Current user account password box,
type your password, and then click Next. The Forgotten
Password Wizard creates the disk.
8.
When the progress bar reaches 100 percent complete, click
Next, and then click Finish. The Forgotten
Password Wizard quits and you return to the Change Password
dialog box.
9.
Remove and then label the password reset disk. Store the
disk in a safe place.
10.
In the Change Password dialog box, click
Cancel.
11.
In the Windows Security dialog box, click
Cancel.
How to use a password reset disk To gain access to your local user account
on a computer that is a member of a domain, or has been disconnected from a
domain, follow these steps:
1.
In the Welcome to Windows dialog box,
press CTRL+ALT+DELETE.
2.
In the Log On to Windows dialog box, type
an incorrect password in the Password box, and then click
OK.
3.
In the Logon Failed dialog box that
appears, click Reset. The Password Reset Wizard starts. You
can use the Password Reset Wizard to create a new password for your local user
account.
4.
On the Welcome to the Password Reset Wizard page, click
Next.
5.
Insert the password reset disk in drive A, and then click
Next.
6.
On the Reset the User Account Password page, type a new
password in the Type a new password box.
7.
Type the same password in the Type the password
again to confirm box.
8.
In the Type a new password hint box, type
a hint that will help you remember the password if you forget it.
Note This hint is visible to anyone who tries to log on to the
computer by using your user account.
9.
Click Next, and then click
Finish. The Password Reset Wizard quits and you return to the
Log On to Windows dialog box. The password reset disk is
automatically updated with the new password information. You do not have to
create a new password reset disk.
10.
your new password in the Password box.
11.
computer), and then click OK. You are logged on to the local computer with your local account
information.
NOTE:-
You cannot use the password reset disk to reset the
password on another computer.
You can use the password reset disk
that you create with only the computer where it was created. For example, if
you have two Windows XP-based computers with the same user names and passwords,
you cannot use a password reset disk that you create on the first computer to
reset the password on the second computer.
You cannot use the password reset disk to reset your domain
account password.
You can use the password reset disk only to reset
the local computer account password. If you forget your domain account
password, contact your system administrator.
The password reset disk contains sensitive
information.
Others may use the password reset disk to gain access to
your computer. Make sure that you store this disk in a safe
location.
I have the same prob.. forgot ny pass for my admin acc
Plz help
how do you make an account without having to make a username & password
