Question about GE JTP20 Electric Single Oven
How to set oven timer on a GE electric stove - GE JTP20 Electric Single Oven
  • Anonymous Mar 13, 2014
    Timer on Electric GE stove is not loud enough
  • 864 Answers
That is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Posted on Aug 28, 2010
SOURCE:
How does one set the clock , timer, cleaner on a GE oven that has a WB19X10006 Electronic Oven Timer
http://genet.geappliances.com/search/search
Here is a link to the GE appliance help page. I believe you will find solutions here for all your settings.
Mar 16, 2011 | GE Profile JTP56 Electric Double Oven
Rachellewis250@I have mislaid my Stoves 720 EF manual. How do I set the timer?
There are five buttons. from left to right they are Minute Minder, Cook Time, Ready Time, Plus, Minus.
To set the time of day press the Cook Time and Ready Time together and then use the plus and minus to set the time. Use the Minus button alone to change the alarm tone.
To set the Minute Minder, press the button and use the Plus and Minus to set the time period. To cancel use the Minus to ge back to 00.00
Jan 07, 2011 | Stoves 720EF Electric Double Oven
Kenmore Classic Wall Oven Model # C97047191-2 Serial # NF91008197 nothing on it works (was fine last night) checked the 3 fuses under the stove and the breaker is good on the electrical panel. Is there...
I think that the ONLY problem is to set properly the TIMER; The TIMER is set OFF and the OVEN does not work; try to push and/or release the timer buttons and it will work. I have the same problem and it is very unfortunate that I have no manuals.....
Oct 05, 2010 | Ovens
Can't get the GE P7 door lock engaged in order to
have to have a repairman come out and reset the code on the inbord computer not a simple fix i know i sell appliances
May 17, 2010 | GE 30" Built-In Single Electric Wall Oven...
Oven will not turn on. Stove top works but Oven elements will not. Oven on indicator light does not go on either
The timer is bad. The timer is a PC Board (Printed Circite) that operates the clock and oven. The stove top eyes are operated by their on switches and have nothing to do with the oven or pc board. Some of them are expensive but not difficult to replace.
Please rate this solution if helpful
Aug 21, 2009 | GE Ovens
Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
Jun 21, 2009 | Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Oven won't stay hot
http://www.lieffcabraser.com/profileovencomplaints.htm
the digital control for the JPT-18 and customer are trying to have GE replace them. It is called the F7 error
Click the link above to see more about the problem. GE wants the customer to pay for the error. Hope this helps. JT
Oct 23, 2007 | GE Profile JTP18 Electric Single Oven
GE JTP20 Electric Single Oven Logo
1,508 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
