After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Here it is in a more readable form... sorry :/
Code 10178 works with Comcast's red OK/Select button remote for the Visio Sound Bar. Here is what I did.
1. Press AUX and wait for the blink.
2. Press and hold Setup and wait for two blinks.
3. Enter 10178.
4. Press Vol t key.
5. Press AUX and wait for the blink.
6. Press Setup and wait for blink.
Now test you remote using your up and down volumn controls. Note: I turned my TV volumn down to 0 so I can only hear my Sound Box. I hope that this helps.
SOURCE: looking for remote codes for vizio sound bar and
(2 blinks)
them:
(2 blinks)
them:
Can some one please help me here. When I followed these steps I did not get two blinks at the end of each assigned code series. Furthermore, it did some thing to my remote where the vilume up button is turning the vizion soundbar off all together.
- I am also unsure of the sequence.....to double check what seems otherwise obvious,
press AUX, then press and hold setup until it blinks twice, then press the 994, then the code, then setup again. (are we holding setup down like we had to the first time around and the start of the sequence?)
it seems pretty straight forward but as you can see, its anything but. If anyone would elaborate a step by step that is exact it would be greatly appreciated. I have been messing with this remote for hours and have pretty much given up unless anyone cares to revive me with better instructions. Thanks ahead of time.
