First turn your Blue Tooth setting to "ON" on your Black Berry Curve, as it searches for a Blue Tooth Device, Push and hold on the middle button of the Blue Tooth until you see a flashing "blue light & red light." It's important that you see both flashing lights.
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Follow the steps below: • Setting the headset into pairing mode 1) Ensure the headset is fully charged 2) The headset must be switch off 3) Press and hold the on button for around 8 seconds until the light flashes red-blue 4) The headset is now in pairing mode • Searching for the headset on the phone 1) Go to “settings” or “connections” 2) Select Bluetooth, then options 3) Select Devices and click add 4) The phone should search for any available Bluetooth devices and display what was found 5) Select the Jabra device and click add 6) You will be required to enter in a pass code which is standard ‘0000’ 7) If successful then the headset will start flashing BLUE every few seconds.
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
u gotta make ur jabra go to FIND ME Mode, u do this by turning it off, Turn it back on by pressing power for 6 to 8 seconds until the light is in flashing mode, and make Ur razor look for devices and pair it with the 0000 code. hope this works for you
Before you use your Jabra BT130, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device. 3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
