Kenmore 92002 / 92004 Kitchen Range Logo
Posted on Aug 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Aug 28, 2010
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232916
Points
12714
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Why won't the oven door lock to start the self cleaning? The door appears to be shut all the way. After hit start, this code appears E1 F5
According to the Whirlpool website, the self-cleaning latch may be interfering with the door, though this would be indicated by an "E0 F5" error code. If that's the case, Whirlpool recommends the following:
1) Press "Stop/Clear" to clear your display.
2) According to Whirlpool, there should be a door switch plunger in the upper right corner of the oven front. Press and hold this so that the door latch will unlock.
However, if it is indeed "E1 F5" (or any other number with those letters in the code), Whirlpool recommends calling an appliance technician.
http://whirlpool.custhelp.com/app/answers/detail/a_id/319/kw/error%20code
tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 • Kitchen Ranges
tip
F5 - E0 Door Switch
Two digit codes:
Regards.
Self cleaning oven
Hello, check door switch,contact should be closed when plunger is actuated.check door circuit for open.
Thanks
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Oven wont work everytime we push bake E1 and F1 appear
Is the display showing E0-F5?
The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
Is the display showing E"#"-F"#," for example, E1-F2?
You will need to schedule service.
1helpful
KEMORE OVEN SELF CLEANING
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
4helpful
Oven door stuck on locked!
E1-F5 indicates door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method next time...
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Remove the motor and unhook the rod from the motor cam. If it is a built-in over, sometimes bending a coat hanger into a hook and sliding from the right side into the lock you can unlock the door.
7helpful
3answers
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
2answers
Whirlpool RF196LX Smooth Top Range
4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
