Question about Zebra 105SL Thermal Label Printer
"warning Ribbon In" error message
I keep getting the warning light flashing and message "Warning Ribbon In" on the printer display, however there is no ribbon in the printer. The Print head was recently changed, would this cause this error? how do i stop it? Thanks for any help.
  • djpop Nov 04, 2008
    Hi all, I have same problem than 2Binspired, but my printer is a Zebra S4M. The message "warning Ribbon in" is displayed when I print something. I checked the Ribbon sensor and nothing special. I cleaned it but same problem. The error message disappear when I put a paper white between the sensor and the plate.... an idea? Regards, Alex from France.
  • cbridg Nov 28, 2014
    Without ribbon the printer should be set to direct thermal.
    New Friend:
  • 13 Answers
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
Posted on Jun 15, 2010
  • Jose Levi Chaves
    Jose Levi Chaves Aug 13, 2014
    Thanks for everybody. This solve my problem.
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a link to a picture of where the sensor is located: https://support.zebra.com/cpws/docs/xi3plus/140xi3plus/images/140xi3p021.jpg
I hope this helps!
Posted on May 13, 2008
Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before.
H.T.H.
BamBam
Posted on Apr 29, 2009
    New Friend:
I have got the labels in line or make it the b but still its showing error RIBBON -IN with printer idle
Posted on Nov 02, 2014
    New Friend:
THE RIBBON IS LOAD BUT THE PRINTER IS NOT SET TO WORK WITH RIBBON, YOU SHOULD CHANGE THIS PARAMETER IN THE OPTION "RIBBON" SHOWS YOU YES OR NOT, YOU MUST CHOOSE YES AND THE MESSAGE DISSAPEARS, I JUST FIXED IT 5 MINUTES AGO.
Posted on Dec 28, 2012
    New Friend:
Warning ribbon in it print 2 labels then stops.
Posted on Sep 25, 2012
    New Friend:
I got this message...opened it up and there was a label stuck to the roller.
Posted on Jan 08, 2010
    New Friend:
Initially checked with above solutions and then tried with below steps which I missed.
After changing the parameter from Thermal Transfer to Direct transfer- you need to then press the Calibrate button on the front of the machine- that's all then you are done - That fixed the problem
Posted on Aug 09, 2013
Did you make sure you put the ribbon sensor plate back in? If not you will get this message
Posted on Jul 16, 2008
6ya staff
SOURCE:
Warning ribbon in V53.16.7Z
The "ribon in" warning is because you set the printer to print DIRECT THERMAL insted THERMAL TRANSFER. The first mode is for printing directly on the thermal labels, not for using a ribon. The ribon sensor detects that a ribon is pressent and you get this message. You need to change the printing mode to Thermal Transfer from the printer Setup Menu, or from the Print Driver instaled on PC.
Jan 19, 2015 | Zebra Office Equipment & Supplies
Warning Error Ribbon In message is being displayed on screen regularly. What can be a proper reason of it?
if use ribbon, change the seting DIRECT-TERMAL to TERMAL TRANSFER, or run manual calibratio and sensor profile, save, turn off the printer, and on again.
Nov 10, 2010 | Zebra Z4Mplus Label Printer
Power light lit Pause light lit data light flashing and display saying printer idle , ribbon out
Press the pause button to take the printer off pause...
The data light is flashing because it has labels to print...
Check to be sure your ribbon is loaded properly.
Jun 20, 2010 | Zebra 203DPI Printer
I have a Z140XiIII that used to have a ribbon and thermal transfer stock. we changed the stock to not require a ribbon, so we removed the ribbon and set the menu to Thermal direct. labels print OK but the...
If the printer is flashing "Ribbon in" then it sounds like the printer setting to Thermal Direct is being changed back to Thermal Trans. Verify this after sending a format. This is very common because the printer is bring over-ridden by the software and/or printer driver when you send a format.
Look for a setting in the software / driver for direct thermal and make the change there.
Hope that helps.
Apr 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Warning Ribbon in
If you're trying to print using Direct Thermal and you have a ribbon installed, the sensor will set off that alarm.
If you WANT to print using direct thermal, remove the ribbon.
If you want to print using ribbons change the Print Method in your front panel setup to THERMAL TRANSFER.
Mar 01, 2010 | Zebra S4M Thermal Label Printer
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
Oct 27, 2008 | Office Equipment & Supplies
My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Oct 15, 2008 | Zebra Z4Mplus Label Printer
Z600 wont print, ribbon error
in the switched at the front of the printer you can configure it to direct thermal mode.. or if you are using printer driver please configure it also to direct thermal mode..
Jul 08, 2008 | Zebra Stripe S600 Thermal Label Printer
New hookup - warning light going on
Take the ribbon out and try it. The carrige also advances the ribbon, and if it is knotted up, thats the problem. Also. look for a photo interupt sensor along the edge of the carrige near the sides of the printer. Chances are, the sensor got dirty and it can not find home.
Mar 08, 2008 | Office Equipment & Supplies
Zebra 105SL Thermal Label Printer Logo
100,228 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
