Canon PIXMA iP3000 InkJet Photo Printer Logo
Posted on May 07, 2008
SERVICE ERROR 6000
I just installed my new canon ip1300, and while trying to print it is giving me a message which says "service error 5100". restart the printer and try again, else refer to the manual.
Also the power lamp and the alarmm lamp are flashing alternately. According to the manual, after restarting the printer if this problem persists, contact the canon service rep.
Do I really need to call those guys?? Or can this problem be resolved?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
648
Points
7
Use this:
1. Turn off printer
2. Hold down Resume button and press Power button
3. Keep holding down Power button and let Resume button go
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more
8. Your printer should respond as normal.
A
Anonymous
It still did not go...
Anonymous
Level 1:
  • Posted on Oct 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
648
Points
It worked for me!!! I just love it!!! =)
-end of message
1 Related Answer
tom19511
Thomas Christopher
  • 1601 Answers
  • Posted on Nov 19, 2007
SOURCE: service error 5100
Error 5100 is either a logic board, or
the code strip (if that is the problem) is another matter -
It is the plastic strip that runs across the printer and through the head
carriage, it is supported at each end (one end under spring tension).
If it has become dislodged it will give this error, also if it has any ink,
grease or other foreign matter on it, it will give errors.
You can clean it with a cloth dampened with water but you need to exercise
great care to avoid pulling it off its anchors.
The other thing to do is clean the stainless steel bar that the carriage sli
des
on and lubricate it with a cloth moistened with 3-in-1 or light machine oil.
If neither of these works then I guess it is repair shop or replacement time
Gives me a code 5100
Canon i550 Service Error 5100 ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/25975
Oct 6, 2006 - I recently dropped my printer out of my car by accident, and now everytime I try to print something, it gives me a Service Error 5100.
Canon Pixma MX420 Printer 5100 Error and Loading Ink ...
? 5:57
https://www.youtube.com/watch?v=tmTJdJTAhYU
Mar 13, 2012 - Uploaded by Dustie Meads
please help me,i have problem in my printer,wifi on printer can't search .... I too was given the generic "5100" error message just tonight.
3helpful
Error message 5100 is displayed
Two questions.
Are you reporting the correct printer model? I cannot find the iP1300 on the Canon website.
Are you reporting the correct Error No? I cannot find an Error No 5100 on the Canon web site.
Don
46helpful
4answers
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Operation failed due to print spooler.
Try downloading the drivers from the following location. This should solve the issue:
http://software.canon-europe.com/products/0010383.asp
13helpful
2answers
Canon pixma ip1300 initialisation problem
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
5helpful
4answers
1helpful
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
1helpful
Canon iP 1300
I am also with the same problem of Canon IP1300, need to know how I can solve this problem of the error 5100, as soon as I bought the product and not used yet, for this mistake, I wonder if this problem is also frequent in the canon machines? !
3helpful
4answers
Service error 5100
des
old marine
old marine
ZJ Limited
ZJ Limited
