SOURCE: what size batteries needed for minn kota 24 volt 74lb thrust
I use Red Hot Mama batteries. These have held up for longer than any other brands that I have used. These are deep cycle marine wet ones.
SOURCE: minnkota trolling motor prop removal
remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
SOURCE: I need to replace the bearings in my Maxxum 65lb
If you never did this before , I strongly advise take it to a local shop....if you don't seal it correctly, you will end up buying a new one for water getting in.... I fix alot of things on my boat but not the trolling motor....your choice....GL
SOURCE: My trolling motor maxxum 74# thrust feels like i
Here's a schematic for your motor:
Maxxum 74 Bowmount
I suspect the the bearings and cups are damaged and binding the tubes. Have a look at key #'s95, 78, 58, 59, 78A, 79. as these are the actual brgs and cups.
Good luck on your repair!
Mike
Testimonial: "Great Thanks Alot"
SOURCE: burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
