I have a dish tv receiver that out puts both hdmi and digital optical audio, my receiver take both hdmi and digital optical audio in and will out put to my tv in hdmi. which is better to have, my dish tv hdmi direct to my tv and the dish tv digitial optical audio to the receiver or should I just use the dish tv hdmi only to the receiver and run hdmi from the receiver to the tv. will any picture quality be lost by going through the audio receiver.
There are no noticable differences between HDMI and optical except price. Although optical is less prone to EFM interference, HDMI can carry a wider bandwidth, depending on quality, but cost a lot especially long runs (10 ft or more). Also optical cables are not prone to connector tarnish which occurs even with gold pins of HDMI
I just got this TV 3 weeks ago. I noticed the AUDIO issue too. Every power up, HDMI change etc, I would have to go into the MENU/OPTION/ and toggle the PC IN/HDMI IN setting to get my Optical OUT AUDIO working.
WARNING:
DO NOT UPDATE TO THE NEW FIRMWARE. :( Tonight I decided to do the Firmware Update on this AQUOS LC-60LE600U with hopes that my audio issues will be fixed.
WRONG... Now I have NO Digital Optical OUTput, and worse, the trick to Toggle (PC IN/HDMI IN) No longer works!!
So now I am out of luck and NO LONGER can use OPTICAL OUT for any of my Dish Network Satellite TV Viewing.
I called SHARP AQUOS Tech Support , firt Rep sucked , had nothing but stupid responses like , use RCA Audio OUT.
Or just plug your OPTICAL OUT from your Dish Network HopperDVR Directly to my A/V Home Theatre Receiver.
I may have to do that afterall!!!!!!! But this simply Bypasses the PROBLEM and doesnt resolve my TV Optical Out Problem.
Then I called , talked to a Very nice guy named Travis. He explained it. I hope some of you can explain it to be better, but here is what he said.
HDMI has some kind of Digital Content Protection, LLC provides HDCP (which was developed by Intel) for HDMI. apparently this is the JIST of this he said. Exoplaining some issue where Powers That Be, (BIG MOVIE CORP) or such want to make it so Digital Audio cant pass from HDMI to OPTICAL as easy???????
I dont get it. So it was never supposed to ....... BUT.. The (PC AUDIO IN/HDMI IN) Toggle trick made it work.
Turns out the NEWER Firmware Fixed it so the Toggle Trick WONT WORK. I cant imagine this is going on. How many Millons of TV Viewers experience this? There has to be more to it than this. My HOPE..... is to find the OLD Default Firmware for this TV, cause even though a Hassle to TOGGLE on the AUDIO, better than NO AUDIO NOW ! ARGH!!!
Please, if anyone can provide ANY info or firnware files for our AQUOS LC-60LE600U I would be SO MUCH HAPPIER.
No no no! # 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
I can't find your TV model to have a look at the manual. Normally you'd use a 3-plug RCA cable (Red, White, Yellow) to connect the audio and video outputs of the DVR to an RCA input on the TV. Then, hoping you have RCA OUTPUTS from the TV, you'd use a 2-plug RCA cable to take an Audio OUT from the TV into one of the receiver's Audio inputs (assuming you want to play TV sound through the receiver.
If you have no RCA inputs on the TV, you can get an RCA to HDMI Converter from Amazon for $10-$15 to convert the output of the DVD player from 3-plug RCA to HDMI, then put that into one of the HDMI inputs on the TV. Likewise, if you have only an OPTICAL audio output from the TV you can get a converter for that -- Optical audio to RCA stereo -- and put that into your receiver as an input.
If your TV has HDMI in and digital optical out, run your HDMI cable via HDMI out on box to, HDMI in on TV then, run digital optical ouyt from TV to digital optical in on reciever. Your reciever has video pass through but, not the best option. Video components should run to TV then out to reciever. If you do not have digital optical out on TV, you may be able to use RCA.
I don't have a direct solution but I am having the same problem when connecting (1) my Apple TV (2) my Blu-Ray player, etc. via HDMI. I also have a digital camera that puts out HDMI, and when I hook it up, I get the same story -- video only, no sound through the optical digital output of the TV receiver.
I am guessing that the HDMI inputs were an afterthought on this model, especially since the printed manual doesn't even show or mention the HDMI inputs at all! So my guess is that the TV's receiver does not convert the sound from the HDMI to the optical digital output. It does, however, send the amplified HDMI sound to the stereo speaker outputs on the monitor. It appears that only the digital tuner's 5.1 sound comes out on the optical digital output.
This is what I have observed, for what it's worth.
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM.
HDMI is mostly set to PCM while Optical is generally Bitstream.
The TV may be set to the opposite of what it needs to be.
I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass.
Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS.
Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers!
I Hope this Helps out!
HDMI is digital sound. I don't know why it's not passing through. You could run a set of audio cables to the surround sound. The not a noticable difference in my opinion.
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
I haven't researched to actual manuals for your equipment, but I'm guessing that the optical may be disabled when the HDMI is used. You could try using the component video outputs to the TV and then the optical to the Onkyo.
