Question about HP Officejet 4215v All-in-One Printer
Office jet all in one printer 4215
I have a hp all in one printer 4215. I can copy, scan, but I can't fax for some reason. It always worked before. It says ringer off and I don't know how to fix the problem.
  • sem10250 May 02, 2009
    When I attempt to send a fax from Solution Center I receive an error message: fax scan failed. I have rebooted both computer and printer. I have reinstalled with and w/o uninstalling the software. I have added all available updates. I have read several forums, including HP's. Apparently as recently as December, 2008 an HP rep. admitted it was there problem, but still no solutions. This problem appeared at some unknown time after a couple of years of successful use on both XP and Vista.
    Problem Solver:
  • 8 Answers
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Posted on Aug 12, 2008
SOURCE:
4215 all in one office yet. When making a copy
Sounds like you're having a problem with the automatic document feeder. The scanner is continuing to scan but the paper is not advancing as it should during the first part of the infeed. Check to see if something is inside retarding the path of the scanned document. Or it could be worn rollers in the ADF.
Jul 18, 2011 | HP Officejet 4215 All-in-One Color Photo...
I have a HP OfficeJet 4215 All-In-One InkJet Printer it is hooked up and i can copy fax and print but can not scan
go to web site of printer model and check site for trouble shooting HP has an awesome trouble shooting site
hope this helps and good luck
Apr 29, 2010 | HP OfficeJet 4215 All-In-One InkJet...
I want to send a fax, but I forgot how. Please help! Gini
press the fax button and dial the number always face down the paper every time. this you is automatically send and receive message
Feb 04, 2010 | HP Officejet 4215 All-in-One Color Photo...
I have a hp officejet 4215. It has a scanner, but
For some reason the scan button on allot of HP printers doesn't seem to work.You can go thru "printers and faxes" on your "start" menu.After opening Printers look in the left column for "scanners and cameras",click it.Then your printer will come up,highlight it.Left column again,click "get pictures" and it will walk you thru the scanning process.
Jan 11, 2010 | HP OfficeJet 4215 All-In-One InkJet...
How do I use my HP office jet v40
Install software from disk or download from HP site
Apr 24, 2009 | HP Office Equipment & Supplies
Hp 4215 all-in-one
If after the storm, your printer suddenly couldn't fax, scan, and copy, my guess is that a power surge fried some of the printer's electronics. You could try turning everything off (printer, Mac) and then turning everything back on. Verify that all of the cords and cables are securely connected, the give it a try.
If it was just one function (fax or scan or copy), there would probably be some specific diagnostic tasks to try to solve the problem, but with that many features going out at once, you may have an unresolvable issue. The only way to be more sure under the circumstances would be to take the printer in for service and see what the repair person said.
Sorry I couldn't be of more help.
Sep 19, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Paper jam in HP 4255 office jet all in one printer
the paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
Jul 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Hp Office Jet 4315 cancell a fax number?
go to the fax number, then try pressing the X button. Other wise if u are ready to loose all numbers, just reset the machine
Jan 08, 2008 | HP Officejet 4215 All-in-One Color Photo...
HP Officejet 4215v All-in-One Printer Logo
217 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
