Question about Honda Electrical Supplies
My Honda EV6010 generator will not start. It turns over fine and the gas tank is full. It ran fine the last time i checked it about 6 weeks ago
  • 1 more comment
  • ESCa Apr 13, 2013
    The automatic choke link has fallen off, common problem. Or, carb bowl needs to be cleaned.
  • glyn
    glyn Nov 06, 2018
    where is bowl
  • glyn
    glyn Nov 06, 2018
    is this the same propane
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Check the oil level, low oil will stop the engine from continued running
Posted on Nov 06, 2018
SOURCE:
witserv
  • 144 Answers
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Posted on May 26, 2010
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 17.5KW Generator dies
If this is one of the big "taco cart" portables you need to check that the vent on the gas cap is open when you're running the engine. In the center of the gage on the gas cap is a little knurled knob, turn it counter clockwise (lefty loosey), about a half turn or so and run the generator.
If that doesn't solve your problem add to it here, otherwise please give me a rating I'm trying to build a little credibility here and could use the help.
Carl
Posted on Dec 02, 2008
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
protek480
  • 1730 Answers
SOURCE: coleman powermate 5500 generator...has about 6
Probably lost the voltage regulator, that's the board you soldered on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 30, 2009
SOURCE: my honda ev6010 engine runs good, but stopped
I am looking for an EV6010 Honda generator. I know they stopped manufacturing them, but I would like to know if anyone has a leftover for sale?
rmhoch@hotmail.com
Posted on Aug 19, 2009
I have an onsn 5500 marquis gold gas generator. We ran it last month for a week during the day. Got home and it ran for a couple of seconds and won't start. Changed the oil and gas tank is full
Check the controller board for overheated components and open traces on it. Make sure the fuel filter isn't clogged and the fuel pump is running.
Apr 16, 2017 | Electrical Supplies
Took my ev6010 generator out and put it back in but hooked up the starter motor to the ground not to the positive and now it wont start. I also changed the oil and coolant.
On the ev6010 Honda generator the posive starter wire is black and was accidently hooked up to the chassis ground wire. Then the start button was pushed and nothing happened. I corrected the wire hookup to the positive side but will not start still
Aug 28, 2013 | Honda Ev4010 Ev6010 Rv Generator Inverter...
Generator does not start
The float bowl their is a drain bolt, take it out check for gas.
Aug 23, 2012 | Dewalt Generator. 6000 Watt Portable...
I have a L120. Up to a week ago I had no problems starting. It cranks fine but won"t turn over. Full service was done a year ago. Thanks Tom
Here are some of the questions that we need answers to: 1 What engine is in your tractor?
2. How long has it been since you last ran it?
3. Did you leave fuel in the tank and/or carburetor over winter?
4. Have you checked the obvious: fresh fuel in tank? gas shutoff valve open? any loose wires? is there spark at the plug? is the air filter clean? is the spark plug clean and properly gaped?
5. When it last ran, did it run okay?
6. When it cranks, does it seem to be at a normal crank speed, or does it just turn over s-l-o-w-l-y?
From what little you told, my guess would be that you left gasoline in the carburetor over winter, and your carburetor is gummed up.
May 22, 2011 | John Deere Garden
I bought a john deere riding mower less than a year ago. i used it last season without any problems. I think the last time i used it, was in august 2010. winter came about, the grass wasn't growing, so...
First, I've had a motorcycle for almost 50 years and have never drained the gas. At one point it was not used for 3 years. It started, I added gas and it ran fine.
Second, next time you are running the machine and it begins to stall, immediately loosen the gas cap. If it starts to run good again, drill out the air vents on the cap.
Gary
Mar 09, 2011 | Garden
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
My eu 2000 watt generator (honda) starts fine, but consistently stops (like it is running out of fuel) after 10 to 30 minutes, then starts up and runs a while longer. I've taken the jet out under the...
My Honda generators have a low oil sensor that automatically shuts them down when a low oil level is detected. I keep a quart handy and top off the oil, and they start and run fine.
Dec 28, 2010 | Electrical Supplies
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My honda ev6010 engine runs good, but stopped generating power. I checked the fuses and the 20 amp and the 30 amp breakers. They check good.
rmhoch@hotmail.com
Jul 04, 2009 | Honda Electrical Supplies
Wont start after 6 mos. I changed the spark plug, drained & added fresh gas, checked the fuel filter... Kicks over fine. Ran for 4 seconds, then it died. Always ran & started great before.
With a new plug and fresh gas it should start. Check to make sure there isn't a kill switch turned off or that the gas petcock from the tank to the carb is on.
How did you check the fuel filter? Disconnecting it from the fuel line that goes to the carb is the best way, making sure the gas is turned on under the tank. Bleed off a little gas into a can or something just to make sure the filter isn't plugged.
The last thing I'd do is take off the air filter and spray a little starting fluid in the carb. It may start and run several times if there is old gas in there somewhere. Remember the bowl on the carb is probably still full of old gas. After some fresh fuel reaches the plug it should start and continue to run.
(You might drain the bowl on the carb of ols gas before you go any further)
Sirwriter
May 22, 2009 | 2006 Honda Civic Hybrid
Electrical Supplies Logo
1,159 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Norman Al-Anbar
Sheldon Dedek
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
