I have the identical problem, wont playback or record. My 1st guess is that the heads need cleaned, but I'm not sure.I have the identical problem, wont playback or record. My 1st guess is that the heads need cleaned, but I'm not sure.
You can't post conmments that contain an email address.
Having camera issues is always a pain, Here are a few trouble shooting ideas to see if it can solve the issue.
try cleaning the playback head: If the audio issue persists with all recordings, it's possible that the playback head may be dirty. Over time, dust and debris can accumulate on the head, affecting the audio quality. Try using a head cleaning tape to clean the playback head following the manufacturer's instructions.
Check the audio output connections: Ensure that the audio output connections (e.g., headphone jack, AV output) are secure and properly connected. If you are using external speakers or headphones, try them with other devices to ensure they are functioning correctly.
Test with different playback devices: Try playing back the recorded video on a different device like a computer or another video player. This will help you determine if the audio issue is specific to the Palmcorder or if the video file itself is corrupted.
Update firmware or software: Check the Panasonic website for any firmware updates or software patches that might address audio playback issues. Follow the instructions provided by the manufacturer for updating your Palmcorder.
Lastly Reset to factory settings: If none of the above steps resolve the problem, consider performing a factory reset on the Palmcorder. This will reset all settings to their default values, and it might help if the issue is caused by a software misconfiguration.
Tengo una camara digital mini DV modelo PV-GS50D 700x, que recien pude repararla, pero al querer bajar lo grabado en mi computador no lo reconoce, necesito descargar los drivers, para un windows xp.
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
