RCA M4204  MP3 Player Logo
Posted on Aug 27, 2010
My RCA LYRA MC4202-A will not load to the main menu, the screen is just stuck on "initializing" when I turn it on.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
533
Points
SAME. NOW IT WON'T OPEN AT ALL
5 Related Answers
A
Anonymous
  • Posted on Oct 12, 2007
SOURCE: RCA LYRA MC5102A
Had same issue with mine, right out of the box!  I called support, they sent me to some 3rd party support company...  That place told me to return to vendor.   Thompson Support.  They basically just tried going to the RCA website, found nothing there, and finished up with return to store...
A
Anonymous
  • Posted on Dec 17, 2007
suck my balls
Anonymous
  • 35 Answers
  • Posted on Mar 04, 2008
SOURCE: RCA Lyra rd2762a
Have you tried replacing the firmware on it? I believe this is the firmware for your model http://drivers.softpedia.com/get/FIRMWARE/Lyra/Lyra-Mp3-Player-RD2760-firmware-207.shtml
Anonymous
  • Posted on May 13, 2008
SOURCE: RCA Lyra MC5102A
connect lyra to computer
go to my computer on your start menu
lyra will show up on other devices or portable devices
double click on the lyra icon
this will bring up another lyra icon right click on that
go down to the option format and select that
you will lose all of your music
solved my problem two hours after it started
A
Anonymous
  • Posted on Sep 05, 2008
SOURCE: rca lyra rd2760 doesn't change from "RCA LYRA" screen
I would try downloading the latest driver, or reformatting the unit. If you haven't downloaded anything, you essentially have nothing to lose, so to speak!
2answers
Produt: Digital Audio Player Brand: RCA Model: M4202,M404, M4208, MC4202, MC4204, MV4208 When powering up it says it is initializing. It has been initializing since Saturday.
Try to turn off player. Remove battery for 15min. Then put battery back and turn ON. If you have extend memory card do the same with MC.
good luck
Rca lyra RD2726A
I think I deleted my recording software or something??just can't play my mp3's..player turns on when I plug into computer but will just continue loading when I try play it
RCA LYRA MC5102A
you just go 2 ur computer where ur hard drive thing is like it says my computer then u open it up and ur lyra should appear there and right click it a menu should come up and itll say format
Rca h100a mp3 player
on the screen just stuck on transferring.....h100a
4answers
RCA LYRA MC5102A
2helpful
2answers
RCA Lyra MC5102A
RCA Lyra RD1021 mp3 player stuck on one song and no sound comes out
Upgrade the player's firmware following the RCA's website instructions (goto support, RD1021, Software upgrades)
Titles dissapearing in Mysel...
Your problem is MusicMatch. In the RCA manual, which is found on the CD or online (nothing is printed), it refers you to the MusicMatch software to learn how to create M3U playlists. Someone at RCA didn't talk to MusicMatch before making this claim. The MusicMatch software makes a mess of the files and never saves a playlist properly. You can devise a process using WinAmp which would probably work with Musicmatch, but I prefer WinAmp. Here's the process: Rip your CDs, download from the internet, and transfer the files to the RD2850 while the Lyra is connected as a hard drive. The files are stored in the /MUSIC directory. I suggest you organize your albums like this /MUSIC// If the artists you listen to have multiple albums, a structured approach is useful. The Lyra can sort the files by Artist and Album automatically if the tags are available, meaning a structured directory approach is unnecessary, but it makes it easier if you want to take the files off the Lyra in the future. Once the files are on the Lyra, use WinAmp to open those file FROM THE LYRA. This is important since the playlist will specify the relative path of the MP3 files and the Lyra expects the playlists in a directory other than where your music files are. With WinAmp open, press L to open the file selection dialog and navigate to the directory with the album, or music. Select the songs, press Open. Open the Playlist Editor (ALT+E) Arrange the songs Save the songs with the List Opts button found at the bottom right of the screen. Chose Save List. A dialog will open asking you where to save the list. Save the list in the /lyra_playlists directory from the root of the drive. Now, the Lyra needs to be updated. This is called "Profiling". The included software has a utility to do this from Windows, or you can do this from the Lyra itself. The manual states if you have over 2500 files, it is best to do this from Windows. But, after changing anything on the Lyra, you must "Profile" the device. You will now see your playlist in the Playlist menu item on the main screen.
2answers
Why is the mp3 player stuck on FM?
sounds like the old stuck button thing. If you wanna take it out of the case maybe you can dislogde the stuck button.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
