SOURCE: hi im unable to conect
This is a
rare problem .... my friend also faced similar kind of problem
he solved this problem with the help of repair
guide.... you can also try this out i hope this will help you a lot .......
all the best
Click Here
SOURCE: error code 32032 (wii)
you need to set up connection for wireless if its a wireless router then set it as connection 2 then search for your router then input the wep-psk or wpa psk code thats on the back of the router
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii."
This means there is either some interference with your wireless signal or your router is simply too far away from the wii. You can try to move the wii closer to the router (or router closer to the wii) or try a different wireless channel on your router.
You can see here for nintendo's official solutions to this problem:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51032&system=Wii&locale=lang
