This is a common problem on the fax-2920. It is caused by a build up of dust and dirt on the ejection roller that stops it from grabbing the paper as it is fed up towards it. To fix it you have to remove the fuser unit for access and wipe all four of the little rubber wheels over with alcohol. Put it all back together and it should be all good!
Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
To print a report
1 Press Reports.
2 Press ? or ? to select the report you
want.
Press Menu/Set.
Solved the problem, it was the High voltage pcb at fault
