I have a HTC TOUC ENHANCED, the same the normal HTC TOUCH but whith bouble memory, when i try to update for another ROM, the devide stay in boot loader! now the devide is dead! can you please help me! i need the original spanish vodafone rom, or a uspl that unlock that situation!
i have the same problem i need the official vodafone ROM to solve the problem is there anybody who can send me this rom ? my device is HTC Touch S ( 64 Ram / 128 Rom ) Model ID : ELF 010050 CID : VODAP304
Language : Spanishi have the same problem i need the official vodafone ROM to solve the problem is there anybody who can send me this rom ? my device is HTC Touch S ( 64 Ram / 128 Rom ) Model ID : ELF 010050 CID : VODAP304
You can find official resources for your phone here, and lost of useful informations about it here.
Hope you are able to sort your problems out.
Regards,
Carlos
when you stuck on g1 big screen, you need: 1. download the right g1 radio 2. download danger spl. be carefull with this, search in wikipedia about it 3. download the latest rom
4. copy all file (in zip) to micro memory 5. enter fast boot (home + power about 20 second) 6. updated files radio first, reboot 7. updated dangerspl, reboot 8. updated rom 9. do hard reset / wipe (alt w) via fast boot all done
Hello and Welcome to FixYa!
Sir, Its sad but true that if you are referring to HTC Touch Diamond Phone, then there is unfortunately no option for extendable memory.
You can see the specs here. (In the Memory section) Got 4Gm in built memory, 192Mb RAM and 256Mb ROM.
If you think I was of help, your token of appreciation in the form of rating will be esteemed. Concerned, Nooh
Regards,
Carlos
It is in bootloader mode and there are 50% chances of it's survival. You can try flashing the phone again (use an original ROM instead of a cooked one, try 3 - 4 different ROMS), in case you are lucky the flashing would complete and your phone shall start again. In case the flashing doesnot complete and you are stuck in Bootloader mode, you will have to get it repaired by Service Center as the chances are that the ROM chip will need to be reinstalled.
i had a hard time understanding your question- but iim guessing its a software glitch.... what i did to reset mine was redownload the telstra rom from the htc site (htc.com/au/- then go support- then in dfrop down choose htc touch hd- then click download on htc toucch hd rom upgrade asia- then choose telstra settings and download- should be like 100 odd mb.... once installed connect hd to com via active sync (make sure more then 50% battery) and open up this rom update... follow installation instructions and let it run (all automatic- only for htc touch hd tesltra bought in aus) - be aware that this will wipe all stuff on the phone (not memory card) ie calendar contacts (so backup using active sync b4 update your rom) after all this turn on your phone again and it should start up like the first time u ever turned it on ie touch calibration and time/date etc (this should fix any software glitches)
i think u have tried to upgrade thru custom rom bcoz this pda came with WM 6 only so u tried to upgrade to 6.1 thru custom rom procedure and it seems like something went wrong and u get a boot loader screen tri color with code written SPL 1.XXX on it dont worry i can help u in this go step by step as soon as ur problem is resolved leave other step
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
pls try to hard reset the device pls backup ur data b4 doing it and take out ur memory card also and see if it gives u screen to select the language to english , other wise u need english rom from www.htc.com just go and download an updated rom from the site and do as directed
if not solved then go to www.htc.com for latest English Rom update download and update backup ur data first
my device p3450 is stock in boot loader and i tried many rom even profissional one is not help which is \r\nDID-ELF010050_CID-DOPOD001_ROM-2.20.721.2B which my device have same info of cid and device number but untel now my device is stock in boot loader that when i try to to update its stop in 3% and it reboot and agine in boot loader stock whith no ruu in top right display but only usb in below disply left and number of old and new rom
my device is
CID : VODAP304
Language : Spanish
same
me too have this problem and i don't know what to do
