Garmin StreetPilot c550 GPS Receiver Logo
Posted on May 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory full on display of the C550
Cleared the recently visited addresses still same problem
Anonymous
Level 2:
  • Expert 504 Answers
  • Posted on May 14, 2008
Anonymous
Expert
Level 2:
Answers
504
Questions
Helped
292927
Points
921
Have you tried updating the unit's firmware? Sometimes this can help.
1helpful
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
3helpful
When Faxing says memory low
The internal memory is full
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts,
if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
I can simplify if needed
14helpful
2answers
I am getting "memory is low/ insufficient memory" in my hp laserjet M2727 printer. what should I do?
The internal memory is full try a nvram.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Al
Memory full error
power off the GPS, then press power button to power it on, press right-bottom corner of the screen during it power-on, will pop-up a button on screen let you to clear user data.
Can not delete address stored
press in 9 * 8 # 7 on key board press the start key use the # key to scroll throgh the options till clear memory is in the display press enter. this will clear ALL memory & reset it to factory settings
3answers
Xerox Phaser 3200mfp Memory Issue
Do you have the receipt for the machine? You have a 1 year warranty from Xerox on that machine, Here is the copy and paste from the warranty information on the Xerox website.
Xerox warrants that the Phaser 3200MFP product and its Consumables, Routine Maintenance Items, and Options/Upgrades (related items) will be free from defects in materials and workmanship for the periods set out below:
Product: a period of one (1) year from the date of shipment.
Garmin Escort C550 GPS
hi there,
It is becoming more often that a sudden message appears filling the screen saying "memory full". I didn't find anything in the instructions dealing with this message. I emptied all added data and information and the message appears untill I pres the OK botton.
Thanks for your help
May 13, 2008 • GPS
Garmin C550 trouble
Try downloading the latest firmware version. This can sometimes help.
6helpful
Screen says memory full and it won't map a route! GRRRRRRR
Hi, Please do not shoot the messenger (me) but this is a known problem with Garmin GPS units. According to Garmin Tech Support, this only occurs on Garmin units with older firmware. (Personally, I am not convinced this is actually true. I no longer have my Garmin C550, which I personally liked the best out of all the GPS units I have owned or used. I will buy another Garmin, probably a Nuvi, when this silliness sorts itself out.) Anyway, you have two options, neither of them acceptable to most people, including me. 1)Perform a HARD RESET which will wipe out all data on your unit, including your favorite points, Bluetooth connections, and almanac data (satellite information). Your unit will then need at least 40 minutes, with a clear view of the sky, to update the almanac and reacquire its location. To HARD RESET, unplug your C550 from the charger and turn it off. With the C550 screen facing you, press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER. You need hold both constantly for at least 30 seconds. Follow the instructions on the screen. See if any of your personal information is still there. If there is none, then you might as well perform Step 2 below. 2)Download and Load New Firmware onto the C550. Upgrading firmware is relatively easy provided you have a computer. Visit Garmin's website (www.garmin.com). Go to "Support" .. "Updates and Downloads" and then click "Unit Software." Download the software called WebUpdater. Run that and follow its directions. The new Firmware (Software that is loaded into internal memory that does not need power to remember the information) hopefully will fix the MEMORY FULL problem. Good Luck and please post back if the fixes helped or not. I really want the new firmware to work so I can buy another Garmin.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
