I have a 1.5 year old counter depth french door refrigerator with freezer on the bottom. Model number KFCS22EVMS. The lid to the deli drawer pivots open when the drawer pulls out. One of the plastic pegs on which the lid pivots broke off rendering the lid useless. I need to see a diagram that identifies the interior trim part numbers so that I can order a new part and replace it. Where can I find a detailed diagram of the refrigerator.
I have the same model and it did the same thing. Problem is, the exploded diagram mentions it as part 16 and 16a. They only show one side. I need the left side as you face the appliance. Any idea of the part number of whether it is 16 or 16a?I have the same model and it did the same thing. Problem is, the exploded diagram mentions it as part 16 and 16a. They only show one side. I need the left side as you face the appliance. Any idea of the part number of whether it is 16 or 16a?
You can't post conmments that contain an email address.
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Hello, Thank You for using FixYa. I will be helping you today.It has to be replaced..You have to call maytag to have a factory tech come out to replace it and it will be covered under warranty.
Thank You and please rate my answer if it was helpful..
The wider end of the piece can be hooked anywhere on the back of the deli drawer. Keep the piece bent when you install it or it will scratch the glass on the front of the drawer. Also, make sure the tip of the smaller end is touching the bottom of the drawer before straightening the divider.
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
