SOURCE: TV Wont turn on blue flashing light when plugged in
Your TV has most likely come into contact with a static discharge. Don't fret it might not be damaged.
My Phillips TV I had came with a built in defense of sorts. The system will shut down and flash the power light as a warning.
Unplug you tv for 5 - 10 minutes and then plug it back in. Give it another try.
SOURCE: my tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
SOURCE: Tv doesn't turn on
Nothing you did wrong caused this problem. Most likely the power supply for the screen failed.
It's best to use the warranty for the TV to fix this problem. Because, parts and labor will cost more than the TV is worth. Here's a link to get you started on the warranty:
http://www.care.philips.com/support/contact/contact_page.jsp?userLanguage=en&userCountry=us&_requestid=24727
