SOURCE: Frigidaire 40 inch range model #REG46NW-2
OPEN THE DOOR COMPLETELY. IF IT GOES BEYOND HORIZONTAL, THE HINGES ARE BENT FROM EXCESS DOWNWARD FORCE. THEY WILL HAVE TO BE REPLACED.
CHECK THE DOOR HINGE SPRINGS TO MAKE SURE ONE OF THEM ISN'T BROKEN. IF YOU FIND ONE BROKEN, REPLACE IT.
SOURCE: Frigidaire Gallery gas range, oven door will not remain open
There may be a broken spring that helps the door stay open.
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
SOURCE: oven door won't unlock
I fixed the automatic oven door lock on my oven. While the door was open, I pushed the button on the upper left hand side a couple of times (the one that senses when the door is closed.) Then I was going to call the repairman when the door closed! I had to run the self clean cycle again to get the lock light to go off, but it worked!
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
