SOURCE: Nokia E71x maps
Yes it comes free. All Nokia Maps will funtion with E71. To update go to the Nokia site of your country.
SOURCE: Nokia N97 Mini
dear,
nokia is about to release its mini N97 in ,09. Further info. can be got by this site..
http://www.slashgear.com/nokia-n97-mini-coming-later-in-2009-1747235/
goodluck!!!!
SOURCE: my nokia n97 mini is
There is a problem with the phone that is why it automatically shuts down and restart.
This is mostly caused by a virus. It might have been contracted by file transfers of different kind.
Either through bluetooth file transfers, file downloads, transfers from laptops and pc etc.
The solution is for you to turn of the phone for a while lets say for about 30 minutes, then you turn it on back. If it does the same, then you can flash the phone with the appropriate software and cable.
After doing this, the phone will be in good condition once again.
Take care and good luck.
TIPS: When a phone gets to work for a very long period of time without getting any break or rest, it will start to malfunction. So as man needs rest after a long time of work so also does any machine to.
SOURCE: i have nokia X6 16
Kindly try nokia master reset code : 12345. If it fails , just get the code by key in your IMEI number at :
www.nfader.su
or
www.nokialockcode.com/calculate.php
Regards, Jay
I noticed same problem after installing the latest X6 software update (21.0.004).
If I view the device in the Windows 7 folder view, the "mass memory" has 0 bytes free.
If I force the X6 USB connection mode to "Media transfer", it will automatically revert to "PC Suite".
The only workaround I've found:
- change the USB mode to "Mass storage"
- copy the music files from the PC to the X6 music directory using Windows Explorer
The downside of the workaround is that the phone then needs to connect to the Ovi music store to validate any music files downloaded from the store.
