Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
Posted on Dec 20, 2017
I have Sony bravia LCD BX300 Problem 1 While playing video file(MPG) through usb a) Video is not being played in full screen. b) No audio only video is being played. Problem 2 How to play audio through home theatre i.e audio system rather than TV speaker. Where I have to fix the audio out cable and how.
5 Related Answers
Jason Morris
  • 362 Answers
  • Posted on Jan 30, 2009
SOURCE: trouble hooking up sony components..Bravia, Home theatre, blu-ray
Got your post, I will work with the model #s. Get back with you soon. Also a tip for now: HDMI carries true digital video and audio so you may not need the optic cables.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Anonymous
  • Posted on Feb 17, 2009
SOURCE: connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
MLFnet
Marvin Fife
  • 328 Answers
  • Posted on Oct 20, 2009
SOURCE: Sony Bravia 40
If you plugged the yellow wire from your DVD player into the "Y" input of the TV this is to be expected. Please refer to http://en.wikipedia.org/wiki/Component_video for information regarding this.
You need to either see if the DVD player has component out, or see if there is a "Video-in" (that's yellow, not green in color) on the back of the TV and change to that input instead.
-=/ MLF /=-
Anonymous
  • 630 Answers
  • Posted on Nov 08, 2009
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Anonymous
  • 56 Answers
  • Posted on Jan 13, 2010
SOURCE: Using a tv as a dual monitor that plays audio from computer
maybe there is something wrong with the way you put the cables in?
5answers
How to play mkv files in sony bravia kdl32ex550
Currenly Sony TV and Palystation only supports videos in MPEG-1, MPEG-2, MP4, WMV, ASF, DivX HD.
In order to play MKV on Sony TV, we had better convert MKV to Sony TV compatible format.
1helpful
2answers
Sony Vegas Movie studio 8.0 - I put in pictures, video and music, but only the music plays. No video or photos appear when I play the video
Because Sony Vegas support WMV, MPG (MPEG-1, MPEG-2, MPEG-4), MP4, MOV, ASF, SWF, FLV, etc. It doesn't support .avi format. So I want to know your video files format.
If ur video file format is .avi format or other video format that Sony Vegas doesn't support. We need convert AVI files into WMV, MPG, MP4, MOV supported by Sony Vegas. AVI to Sony Vegas is a good solution to import AVI to Sony Vegas for editing.
Video Converter Platinum is the most advanced AVI to Sony Vegas Converter software which can convert HD videos (inc.HD TS, HD MPG, HD MPEG, HD MP4, HD AVI), TOD, MOD, MTS, AVI (DivX, Xvid, etc.), QuickTime Video, 3GP, VOB, etc to Sony Vegas.
Free Trial:
http://www.4yousoft.com/video-converter.htm
Good luck~~
2answers
MKV file - video slower than audio
Mkv files to play correctly require quite powerful computer. Try mpg, MPEG codes but even those when used for high definition video my require some processing power.
Pulsing/skipping picture on Sony Bravia 52'' LCD flat screen TV.
Yes it sounds like a lemon. A firmware update is the next thing to try.
PS3 and Sony Bravia
one of your lasers in PS3 is probably bad
What format does a .mov need to be converted to to play on a DF?
You can try these these file formats and compression rates:
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio
You will have to look for a free video editing software and use it to be able to follow the above formats.
3answers
How can I view the footage recorded on the DVD-Camcorder?
-Press ‘Play’ on the camcorder and review the footage on the 2.5” LCD screen -Connect the DVD-Camcorder to your television using the supplied Audio/Video cables -Download the file to your PC using the supplied USB 2.0 interface cable(not available on DZMV730A) and view it using a Windows MPEG Player application that supports DVD recording format (.vro file extension). -Finalize a DVD-R or DVD-RW disc and play it directly through a home DVD player.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
