Hitachi NV45AB2 Roofing Coil Nailer  Logo
Posted on Aug 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air is leaking through trigger when trigger is not depressed. When trigger is depressed and nail tail cover is in safety position (holding gun in air) it completely stops. The gun fires well but there is just a significant amount of air escaping when trigger is not depressed. Could it be the valve packing near the urethane ball in trigger?
Anonymous
Level 3:
  • Master 2,176 Answers
  • Posted on Aug 26, 2010
Anonymous
Master
Level 3:
Answers
2176
Questions
6
Helped
1311158
Points
5445
Could be either that or a damaged o ring, when was the last time serviced, all o rings replaced?? could be that the tool needs a thorough cleaning and new one installed. it is not hard
  • 1woodworking Aug 26, 2010
    Thanks for the advise. The gun really has very little use although almost 10 years old. I think it may be time for a thorough interior cleaning/maintenance. Do you know if there are kits that include necessary O rings and frequently serviceable parts?
  • Anonymous Aug 27, 2010
    yes there are, the kits that I installed had everything except for the lube for the O rings. I suggest yellow pages and finding a Hitachi dealer near you or you can get them online from Hitachi
Nailer wont advance the nails then it shoots blank
Try ez test to check for proper operation. Remove nails and air supply, point nose of gun up then down again. The driver should not move from the top of cylinder position. If driver is moving up then down replace the driver oring. If driver oring seems ok then connect air supply and bump fire the nailer without nails against soft wood and door open so that you can see the driver and feeder moving. Bump fire the gun and make sure that the driver is moving all the way back up to top of cylinder and the feeder is moving rapidly back and forward. If movement seems ok then hold the nose down on soft wood and depress and hold the trigger. This will fire the gun but driver will stay at the bottom position and not return until you release the trigger or lift the gun. When holding the gun with the driver down position, no air should leak out the top or bottom of the gun. If air leaks out bottom, replace lower bumper, if air leaks out the top replace the upper bumper. Good luck
I have a Hitachi NR83A3 framing nail gun. It won't drive nails flush. Adjusting the depth screw from one extreme to the other doesn't appear to help or change the driven nail depth. Any ideas?
Easy to check. Remove nails from gun and connect to air supply. Using hard rubber pad or soft wood depress and hold trigger and push nailer safety against pad and hold there. The gun will fire but the driver will stay down until you pull back on the gun and relieve pressure on the safety foot. With driver down examine the tip of the driver. It should look square and should extend about 1/4 inch or more past the nose. If tip is broken replace driver. If lots of air is leaking past the nose during test, also replace the lower bumper. Good luck
1helpful
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
I put a new o ring rebuild kit in my Bostitch N80 sb framing nailer. I replaced every o-ring (including the trigger valve assembly
If the new trigger valve leaks air when you connect the air supply, most likely defective valve or air is leaking past outer trigger valve orings due to debris in the slot or new orings were cut when the valve was pushed in. If air leaks when you depress safety to fire gun then most likely problem is in the head valve or safety foot is not pushing the firing pin all the way in. Easy test, remove nails and remove the trigger to expose the firing pin. Connect air and very quickly depress the firing pin all the way in. If the gun fires, adjust the safety foot as needed. If the gun does not fire, remove the head and check headvalve orings for good snug fit against the cylinder within the head. The surface were orings make contact must be very smooth and not too deeply worn. If you notice fine scratches remove with fine sandpaper. Reinstall head using plenty of white grease on all the orings within the head and retest. Good luck
2answers
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
2helpful
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Only shoots out one nail for every 4 or 5 trigger pulls
The gun will miss fire if the driver does not return to top position allowing nails to move into position. Could be bent driver, faulty trigger, cracked lower bumper or check valve not in place. Easy to check if trigger. Remove air supply, and remove the pin holding the trigger. Fire the nailer by depressing the firing pin with your finger. If the gun works ok, single fire trigger is faulty or safety foot is out of adjustment. If still miss fire, remove head and pull out cylinder and piston. Check for bent driver, cracked lower bumper or black band (check valve) is out of place on outer part of cylinder covering a row of holes.
Hi there, bostitch framing gun f33 pt leaks air around trigger when i try to shoot nails.only when i use the trigger air escapes,otherwise it is sealed .just want to make sure what is your advice , before...
There are about three issues with this gun that could cause your problem. The safety contact arm not depressing the trigger pin fully, worn trigger valve (tva6), or leaking orings in the headvalve. Easy tests. Remove the nails, and remove the trigger to expose the tva6 valve. Reconnect air and with very quick and firm action, depress trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is depressed all the way in each time that you fire the gun. If the gun does not fire, remove the head and remove the headvalve. Examine the surface/s where Orings make contact with magnify glass looking for fine scratches. Sand with 400 grit paper. Orings must make good contact here or gun will not fire. Lube orings and surface with silicone paste lube (sold at Lowes in the plumbing department or swimming pool supply store). If no fine scratches and surface looks smooth, replace Orings in head and the tva6 valve. Good luck with your repair/
1helpful
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Top Hitachi Tools & Hardware - Others Experts
vince
john h
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
