Watches Logo
Posted on Aug 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my watch has been fogging up which makes it impossible to tell time at allthis only accurs when i am actually wearing it what can i do to get this problem fixxed
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 26, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
457802
Points
2634
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
2answers
How to change the battery. I can't get the back off to get to it.
You need to take the watch to a watch expert. Most watches are not designed to be serviced by the owner. There are a couple of national chains of watch repair stores that specialize in battery replacement as well as a vanishing number of full-service watch repair shops. Most jewelers are not trained nor do they have the tools to do a proper battery replacement. Since this is a water resistant watch, make sure the place you take it to can re-seal the back and pressure test it to ensure the water resistance. The best place I've found is Precision Time. They are located in most major cities in major shopping malls and can service the watch while you shop. Check out www.precisiontimeco.com for nearest location. There are also a lot of FastFix locations around, but most are not able to reseal the watches.
Relic model zr66023 165 ft under water watch. how do you light the light to see numbers. 2 buttons on side, buttons on side push in but no light
This particular watch has no light. The two additional buttons are for the chronograph (timer) function. The top is the stop/start button, and the bottom is the reset button. Source: I own this model of watch and have the book on it as well.
I have a fossil watch model fs4255 leather strap dress amber dial and I want to open back to remove old battery and replace with a new. i have a watch repair tool kit and replace all my own watch batteries...
mcdevito75 here, Even with the proper tools we still have to improvise at times, Instead of useing your case opener from your tool kit, use a steak knife or similar with a sharp edge inside that groove you"ve described, the cover will pry off.
Armitron wr165 ladies watch
WR 165 simply means Water Resistant to 165 feet. The model of your watch is stamped on the back of the watch face.
Check out this website for possible instructions, and at least they can sort of help you get started....
http://www.armitron.com/watch_instructions.asp
3helpful
Rhinestone fell out
No, this will not be covered on the warranty. You have to visit your nearest watch repair shop or jeweller and ask to fit a new stone. It is easy job and shouldn't cost too much.
Jan 08, 2009 • Relic watch
1helpful
Alarm
hold adjust button down at same time press mode and start/stop button until it beeps.
hope this helps!
Top Relic Watches Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
