I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
My 2002 vintage RL70 system had continual "no fix" or "lost fix" messages through 2006 and 2007 seasons. Raymarine rep suggested replacing the 120 GPS receiver with the 125 receiver. I did this past winter and the problem disappeared. The 125 receiver is better technology....not one "lost fix" since replacement.
I have this unit for sale brand new, with everything with it.
[email protected]
www.shaverstreetmarine.com
Your GPS unit is broken. Check the connections and if they are all ok - buy another unit.
I have the same problem with my RL 70C. Two weeks ago it started giving the NO FIX message. As far as I'm aware, nothing has been knocked or disconnected. Any help would be appreciated.
Phil
