Question about Microsoft Xbox 360 Console
I put on a family timer on my sons xbox and i can remember the pass code
    New Friend:
  • 27 Answers
To reset your pass code, repeat this procedure at any time.
i put on a family - spacer.gifReset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it
Posted on Aug 27, 2010
SOURCE:
I need to lock my xbox
You can use a Family Setting Pass Code to restrict access
http://www.xbox.com/en-US/support/family...
You can also set Family Timer settings to restrict time
When they type in the wrong pass code, they can access the reset pass code question. So just make sure they can't guess the answer to your pass code question or you might find yourself locked out.
Source(s): http://www.xbox.com/
Dec 11, 2013 | Microsoft Xbox 360 Console
Cant get into family settings as dont know code. Son put code in now he cant remember it
Only Option is formatting your hardrive and then restore your username
Thanks
www.1RepairStop.com
We Fix Everything
Sep 01, 2011 | Microsoft Xbox 360 Console
I bought my xbox 360 from a buddy a few years back and my brother as of recent has been an *** and i want to set a passcode of the 360 itself so he cant use the xbox live without the code. and there...
From the System area of the Xbox Dashboard, select Family Settings, Console Controls.
You will be told that your pass code is incorrect. Select Reset pass code.
You will then be shown your pass-code question and asked to answer it.
Hope that helps, best of luck.
May 24, 2011 | Microsoft Xbox 360 Console
I forgot my family passcode and the answer to the secret question on my xbox 360 what should i do?
Hi aureliogovea
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to control access to features and options. Because Family Settings exist for both the console and for Xbox LIVE accounts, you can set pass codes for both.
Here you can learn how to:
Set an Xbox LIVE Pass Code
When you set an Xbox LIVE pass code for your profile, anyone who wants to use that profile will need to enter the pass code before signing in to Xbox LIVE.
To set an Xbox LIVE pass code:
  1. Go to My Xbox and open your profile.
  2. Select Manage Account, Xbox LIVE Pass Code.
  3. Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
  4. Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You will have to enter your original Xbox LIVE pass code before you can create a new one.)
Set a Family Settings Pass Code
When you create a Family Settings pass code, anyone who wants to change family settings on your console will need to enter the pass code first.
You can also use your Family Settings pass code to override game and movie settings if you (or those with whom you share your pass code) want to play games or watch DVD movies that your console settings normally block.
For example, you could give the pass code to your 18-year-old so that she can watch R-rated movies that your younger child is not allowed to see.
To set a pass code for your console:
  3. Select Set Pass Code.
  4. Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
  5. Confirm your code by entering it again.
  6. Choose a pass code reset question.
  7. Select Pass Code Reset Answer and enter your answer using either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console.
  8. Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Jan 24, 2011 | Microsoft Xbox 360 Console
A couple of years ago i made my xbox live account and accidentally set the family settings to high now that im using my xbox agian i cant really do anything on live since i dont remember my password or...
Oct 16, 2010 | Video Game Consoles & Games
I bought a used Xbox360 and the family timer is set on it. I want to reset this but unable to. There is a description on here that is a gentleman explaining how to solve the issue but its not working for...
When the Xbox 360 Family Settings are first setup, you are required to give it a four-button pass code in order to add or change settings.
There are two ways to edit or remove the Family Timer.
If you do have the pass code:
  3. Enter your pass code.
  4. Select Family Timer.
  5. Select Disable.
  6. Select Done.
  7. Select Yes, save changes.
Now your timer should be disabled!
If you do not have the pass code:
  • Try contacting the previous owner.
  • Call Xbox Customer Support at 1-800-469-9269
Note: Some information taken from Xbox Support.
Family Timer
Pass Codes
Oct 06, 2010 | Microsoft Xbox 360 Console
My dad put on a timer for my xbox 360 and i want to find out the pass code. the pass code is a 4 button code its either A,X,rt,rb,lt,rb,up,down,left,right
Stop talking back,Take out the trash, clean your room,Do your homework,Tell Dad you will get all A's and 1 B on your report card.
It worked for my sons and I took off the timer.
There is another way but I'm not telling until I see your Report Card.
Sep 02, 2009 | Microsoft Xbox 360 Console
Can u give all the combinations for family setting problem.
Reset a Forgotten Pass CodeTo reset your pass code after you've forgotten it:
Aug 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 password recovery
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-555-741. They will resolve the issue for you
Hope that helps
Scanss2k
Aug 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
538 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
