Open the Applications folder on the hard disk on which MP Navigator
is installed, then open the Canon Utilities folder and double-click the
MP Navigator 3.0 icon
. MP Navigator opens.
2. Point to
Scan/Import and click
'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select
'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
- When you select Color Photo or Black and White Photo,
the position or size of the image may not be scanned correctly if you
do not leave 3/8 inches (1 cm) or more space between the edges of the
- When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
- When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
- When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
