Computers & Internet Logo
Posted on Aug 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My erthernet card doesn connect when i put a cable ,it says cable unpluged..how do i fix it
Che Que
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jun 05, 2019
Che Que
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
996
Points
25
First check your router or your modem if the LAN connection led is blinking, if not, there is a problem with either the cable or the modem, isolate the problem. if its the cable then change the cable, if its the modem then you should know what to do. then if both are good, uninstall the driver of the network adapter, through the device manager and reboot your PC. hope that helps
goneforever.
Level 3:
Top Expert:
  • Compaq Master 14,531 Answers
goneforever.
Compaq Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263958
Points
66315
No PC stated. why post lacking such KEY FACTS?
no OS stated windows what? do not run XP ok if is.
does device manager shows the ethernet ok ?
connected with cat5/6 cable to your router
does the router connect other PCs via this cable ok?
try a 2nd cable, try all router ports ethernet.
what card is it, many do not work now, like old 3COM cards.
a card means and PCI-express card, and not usb Gongle.
I can't see your PC so, answering is very hard.
the cable is not seated correct on both ends.
The router is dead.
on old PCs we must force feed the driver, after all
plug and play is dead, with dead ethernet port,
so that is what must be done. (lacking wifi)
JenniferT
Level 1:
Habit-Forming:
New Friend:
  • Contributor 22 Answers
JenniferT
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
22
Questions
0
Helped
9069
Points
84
Here are several fixes you should try:
1) Reboot your computer
2) Check your network cable and router
3) Update your network adapter driver
4) Change the network adapter's Duplex mode
Anonymous
Level 3:
Genius:
  • Master 2,785 Answers
  • Posted on Aug 25, 2010
Anonymous
Master
Level 3:
Genius:
Answers
2785
Questions
Helped
859992
Points
7964
Plz try by reinstalling the ethernet driver, if the problem is not solved then check with a working lan cable.if your ethernet card is working with another lan cable then your ethernet card is faulty other wise your cable is faulty.
How can you fix just a black screenThe TV was fine when I went to bed I did leave it on all night and when I got up the next morning I had sound but the screen was completely black
    How you would fix a black or blank screen on your TV.
  1. Ensure that the power sources for all your devices (TV, digital box, VCR, etc.) are securely connected to your devices and the outlet. If that doesn’t fix it,
  2. Check that your TV is set to the correct input. If that doesn’t fix it,
  3. Unplug the power cord from your digital box, wait for 30 seconds, then plug it in again. Wait until the box has fully powered on again, then see if the picture has returned. If that doesn’t fix it,
  4. If you have an HDMI cable connected to your TV, you could try an HDMI handshake.
How do i setup a desktop for wireless form router to another pc
connect the other computer to the same wifi network and then open the browser and use the following link 192.168.0.1 it should work
then it should ask you for user and password of your router
I hope it helps.
Arris tm502g/ct is not connecting
if online fails on modem
call the ISP,
only they can fix it.
or first unplug AC to modem for 5min and put back to safely reset mode, and watch the ISP do the reload.
1helpful
Horizontal blinking lines appear on the screen of Sony Vaio VPCEL 10EL
Possible cause:
1. Video card failure.
2. Bad connection between video cable and LCD screen.
3. Bad LCD screen.
4. Faulty video cable.
Possible troubleshooting steps and repair solution:
1. First of all, test the laptop video output on the external monitor. If you see same flashing lines running through the image on the external monitor, you have a problem with the video card. If flashing lines appear only on the laptop screen, the failure is not related to the video card.
2. Just in case, try re-seating the video cable connectors on the motherboard/video card and maybe the back of the LCD screen. It' s not likely but possible that connection is loose and reconnecting the cable will fix the flashing lines.
3. If re-seating the cable connectors doesn't help, most likely you have a faulty LCD screen. The LCD screen has to be replaced.
4. If replacing the screen doesn't help, try replacing the video cable. It's very unlikely that this problem is related to the video cable but there is a slight possibility of that.
1helpful
How to hook up my wireless dell laptop to a hardwired desktop setup? Is there a card to use or hard wire some how is the answer?
you will need to buy a router. Home use router usually comes with network 4 ports. Plug the cable from the modem to the router then plug the desktop and your laptop to the router.
1helpful
Can i hook up wrt120n to laptop without hooking up to cable modem to fix?
Try this: Unplug EVERYTHING(related to both the router and modem). BEFORE you plug in power to anything, connect all of your ethernet. So, first ethernet goes from modem to router. Make sure they are in their proper places. Next, take another ethernet cable and attach that from modem to computer. NOW, power everything up. Google the linksys router splash page login. Im sure it'll be something like: 192.168.1.1 or 192.168.0.1 or something along those lines. From there, you should be able to set up your wireless. Once thats all good, unplug just your computer and everything should be fine. If that doesn't work, its either time for a new router or you're having wifi card issues.
2answers
HP 1550E Desktop soon as you turn it on the fans come on and the Monitor goes to sleep ....I have replaced the power supply, Mother Board checked all the connections and still have the same problem,,,HELP
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty:
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
3helpful
3answers
No signal to monitor
Check all conections between the tower and the screen, make sure all are secure, if no joy, unplug the tower and remove the side panel to see if the graphics card is in securely, maybe take the graphics card out and put it back in again to be sure. If you have another monitor or monitor cable try replacing to see if the situation improves.
1helpful
Error 321
Are you trying to connect a computer to the network or it is another wireless device.
For this you don't need to use Linksys Easy link advisor.
All you need to do is, open the router set up page and check the settings of the router.
according to the settings on the router, you can connect the new device to the network.
is ther any computer connected to the router?
use that cmputer to open the router set up page.
I have 4 pots and 1 yellow where do i put my
Well you have netgear wireless router.On the back side you have 4 ethernet port where you can plug a cable which is coming from telephone.Its up to you if you want a wireless and your computer don't have a wireless adapter then to get a wireless connection you required a wireless adapter.Ya you can use internet connection with erthernet cable also
Hope this will resolve your issue
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
