SOURCE: Hello: I have the TI PocketMate
It has to do with the contrast of the screen and has to be reset.
Solution:
1.Turn on power and press Enter.
2.Operate the cursor down till the screen brightens up enough.
3.Press another menu ie notes, now the contrast options for display are set.
That's all
SOURCE: Data Transfer Failed
Nathan Price says:
I had the same download problem, and after fiddling with the pedometer
for a couple of hours I figured out the basis of the problem and was
able to fix it. Being a software engineer, I figured that since it
copies each day's data to memory once the clock clicks over to 12 AM,
there must have been one day somewhere that had corrupt data. The
download would always reach a certain percentage and then fail and as
more days were saved, the percentage went up slowly. Unfortunately,
Omron does not provide a mechanism to clear the internal memory inside
the pedometer, which it really needs to do. The reset button on the
back does NOT do this. The software on the computer has nothing to do
with this problem. It is completely internal to the pedometer itself.
In any case, to fix the problem, I just started setting the clock to
11:59 PM, waiting a minute and doing this quite a few times until the
corrupt day's data was pushed out of memory. It holds 42 days, so
eventually the data will be erased. Well, it fixed the problem! Of
course, when the download finally worked the data was all screwed up.
Then I just exported all the data to CSV, opened it up in a text editor
and fixed the screwed up days, then re-imported the CSV file using the
software.
Unfortunately,
this whole process takes patience and a good knowledge of computers and
software. Shame on Omron for not making it more user-friendly and
providing a button to clear the memory or enabling the software to skip
over and delete corrupt data. But hey, that's what you get for $30,
software developed in India.
SOURCE: page plus blackberry data not working
Contact Jason at Greenville Wireless. He can fix your problems with Blackberry's on PagePlus. You can reach him at 864-283-5467.
SOURCE: when asked on a job
This implies that the company might be intrested in yer resume or your performance at the interview. So they would rather listen to a positive and impulsive answer from your side. So do not hesitate in leting them know that you will be most pleased to work with them and also let them know an appropriate date or in the weeks to come when you will be able to join. You must note that if you are already working in a concern then it is VERY necessary that you file your papers with the company before itself. Because in few concerns you will have to file the resignation before 2 months or so. This will help you decide on when you are likely to start your work with the new organisation.
SOURCE: Can a employer force me
If that person is causing you to miss work or is coming onto the job and causing a ruckus... yes....
You are probably lucky that they are giving you that opportunity and not just firing you...
heatman101
