Mitsubishi WD-60735 Projection Television Logo
Posted on Mar 31, 2017
Mitsubishi WD-60735 TV doesn't respond to the remote control at all (on, off, volume, input, etc) and has to be powered on and off manually at the control panel of the TV. Volume menu is stuck on screen but picture and cable work fine. the remote control has been replaced with batteries, does light up when buttons are pushed and ensured volume button is not stuck. i have tried pushing the system reset button twice on the control panel, unplugged the tv and waited 1 minute, pushed menu and format at the same time on the control panel but nothing works, the volume menu stays on screen and the remote for the tv does not respond to any commands other than to light up. any suggestions?
5 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Nov 13, 2007
SOURCE: Mitsubishi WD-52525 projection TV volume control
Check owner / operator manual for "panel lock" selection or
go through menu pages until you spot it........
This selection is made so guests or children cannot operate tv.
In case this suggestion fails, you might try hard reset = unplug
AC cord overnight,then try again...........T.
Anonymous
  • 27 Answers
  • Posted on Dec 06, 2007
SOURCE: Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at [email protected] if this helps
Anonymous
  • Posted on Aug 31, 2009
SOURCE: Remote won't turn tv on. Powers on at tv but
Looks like the core of the problem is this:
microswitches on the frontcontrol board leaking.replace it.
http://www.fixya.com/support/t2422987-same_problem What worked for me was this: Supposedly, the front panel is known to have leaky switches. power,volume,menu,etc.. They asked me to take my finger and rub left to right back and forth hitting all the buttons, do this about 20 times.. then poke the reset button in and out a few times.. Wait about 60 to 90 seconds and see if your green light quits flashing.. If so, try powering on with your remote.
http://www.hdtvoice.com/voice/archive/index.php/t-18816.html
Anonymous
  • 556 Answers
  • Posted on Oct 23, 2009
SOURCE: I have a Mitsubishi WD-60735 Television and after
Sounds like a bad color wheel.
Anonymous
  • 556 Answers
SOURCE: Mitsubishi WD-62827 shuts down after pushing the device button.
With the remote press menu 2470 enter then do a system reset after the set has reinitialized this should fix your problem, you will have to reprogram your channel settings afterwards though.
Testimonial: "Thank you so much for your expert advice. Your solution saved us a great deal of trouble in trying to transport a 62" projection tv. Thanks again!"
I have a Mitsubishi WD-Y57 1080P. I knew that my bulb was about to go because it was getting dim. I have replaced the bulb twice in the past. This time however, the day before it totally died, the...
Is your remote control possibly bad? Is it set to other than TV mode? Batteries? Nothing to do with lamp, but TV must turn all the way on for remote to operate anything besides power on/off. --Remote is a function of TV microprocessor.
Timer is on and Tv will not come on
Press the System Reset Button which is on the RHS on control panel
If the TV fails to respond to the remote control, control panel
buttons, or will not power on/off, press the SYSTEM RESET button on the control panel.
The green LED on the front panel will flash quickly for up to one and a half minutes. When the green LED stops flashing, you may turn on the TV. Recent setting changes you made before using SYSTEM RESET may be lost.
If that fails try pressing and holding the menu button for 8 secs
user manual is here:
http://content.abt.com/documents/19051/WD_C-735-736-835-series_om.pdf
2answers
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
2helpful
My WD-60735 doesn't recognize my xbox 360 in HDMI or AV. DVD player works fine in AV, Xbox works fine in HDMI and AV on another tv. Just goes to blue screen on this tv.
have you set your settings for 720p on your xbox then turn the tv on to the right input then turn the xbox on? i had that issue with a previous tv? does the lights on your xbox just spin around?
How do i change the lock code on my mitsubishi md-60735( 60'' ) tv? also please, why can only turn on and off my tv with only the remote? please help.
The only way to reset on a lock code on a Mitsubishi TV is going to be reseting the unit. I believe this unit is reset by holding down the power button for 10 seconds while the unit is turned on. As for the remote being the only way to turn the TV on, does the button on the front of the unit stick, or seem 'smushy' when you press it?
1helpful
The picture is very dark
Sounds like your lamp/bulb is about ready to die. Here is a google shopping list for some replacements if you choose to DIY. http://www.google.com/search?q=Mitsubishi+WD-60735+replacement+bulb&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#q=Mitsubishi+WD-60735+replacement+bulb&hl=en&client=firefox-a&hs=XxY&rls=org.mozilla:en-US:official&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=k7KtTZP4A4jk0QGYm6jHCw&ved=0CHwQrQQ&biw=1366&bih=650&bav=on.2,or.r_gc.r_pw.&fp=30e0fb8dc28dda8
Also if you need help on the DIY just come back. But a detailed reinstall can be found in the manual starting on page 75 which if you don't have can be found here:http://www.mitsubishi-tv.com/pdf/ownersguides/WD-60735.pdf. Also on that page is a part number and phone number to get replacement direct from Mitsubishi. Good Luck!
1helpful
I have a mitsubishi wd-60735 tv when i turn the tv on nothing comes on only hear the volume and screen just pitch black?
Did you recently replace the lamp? If you did then it might be the new lamp. I mistakenly bought an aftermarket lamp to replace mine and it would not work consistently. Apparently if it is not an Mitsubishi original lamp it has issues, because after I replaced it with a Mitsubishi lamp it worked perfectly fine.
2helpful
Mitsubishi Wd 60735 will not turn on
replace the color wheel p/n 938P137010 MODULE-COLOR-WHEEL
4helpful
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
