2004 Dodge Caravan Logo
Posted on Aug 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to adjust parking brake. do you need to take anything apart?
Anonymous
Level 3:
  • Master 5,081 Answers
  • Posted on Aug 25, 2010
Anonymous
Master
Level 3:
Answers
5081
Questions
Helped
2235278
Points
18738
You cannot adjust the cables on a minivan manually. the tension is automaitcally adjusted by the self adjuster on the pedal release.
The park brake cables on this vehicle have an automatic self adjuster built into the park brake pedal mechanism. When the foot operated park brake pedal is in its released (upward most) position, a clock spring automatically adjusts the park brake cables. The park brake cables are adjusted (tensioned) just enough to remove all the slack from the cables. The automatic adjuster system will not over adjust the cables causing rear brake drag.
Due to the automatic adjust feature of the park brake pedal, adjustment of the parking brake cables on these vehicles relies on proper drum brake.
When the park brake pedal is applied the self adjuster is by-passed and the pedal operates normally to engage the park brakes.
When a service procedure needs to be performed on the park brake pedal or the park brake cables, the automatic self adjuster can be manually locked out by the service technician.
2 Related Answers
jeffbvegas1
Jeff Barton
  • 520 Answers
  • Posted on Jun 25, 2009
SOURCE: saturn sl1 99, parking brake needs to be adjusted
you can pull the center console with phillips screw removal and find the adjuster for the hand brake towards the rear . 12 mm wrench required if memory serves me
Anonymous
  • Posted on Oct 03, 2009
SOURCE: How do I adjust the parking brake cable on a 1991
If the car has a center console between the seats, and the e-brake lever is there, remove the console there should be a bolt to tighten or loosen. Loosen it with the lever DOWN, pull the cable as tight as it will go with your hand and a pair of pliers. Holding the cable in place tighten the bolt or nut that secures the cable. If this doesn't fix it, have your rear brakes inspected and/or adjusted.
Testimonial: "Fixed the problem. Thanks!"
Hello How Do I get the emergency brake to release ?
There may be a parking brake adjuster, loosen it off, see if it helps? Next, get at the rear brake assembly, if there is a star adjuster loosen it off, hopefully, that will loosen the brake pads? At the rear brake assembly, maybe you can get at the parking brake cable?
I can't see anything from here.
Safety is your responsibility, if you get brakes released, you need to make sure brakes work properly before driving, again.
How to adjust 1999 alero emergency brake
Care must be taken doing this as the rear brakes shoes must be adjusted first, or you will have issues.
Next with the drums off and the parking brake fully released look at the cables under the vehicle, you will see a threaded rod for the adjustment. Move the rod until the cable barely has any slack in it. If you can not get the drums back on the car, then it is to tight.
BE VERY CAREFUL NOT TO APPLY THE NORMAL BRAKE OF PARKING BRAKE WHEN THE DRUMS ARE OFF THE VEHICLE, IT CAN MAKE THE BRAKES COME APART AND EVEN DESTROY YOUR WHEEL CYLINDERS!!!!
Put the drums back on and check it's operation.
Need to replace parking brake cables on 1986GMC S15 4x4
most people find this out after they put their boat in water.
good time to service the rear brakes seeing it all has to come apart to change the cables. chances if the cables are siezed the rear adjusters are too!!!!!!!!!
2answers
I left my car (Mercedes C180 auto 1994) with a mechanic to replace the back and front brakes. In the process, the mechanic said he had to replace the calipers on the brakes. When I drove the car home and...
I would say one of two things happened. first maybe the parking brake shoes need adjustment. the most common that i see all the time even with newwer cars and trucks, the rear brakes are set up two ways, the type your car uses is the disc rear brakes used to stop the car and then for the parking brake it uses shoes inside the rear of the brake rotor, inside the rotor it gets very rusty and the shoes tend to rust awat from the metal mounting braket it comes on. i see this all the time, when you go to remove the rotor as you slide the rotor off the shoes fall apart and can not go back on, as along as the rotor is not removed it will stay in place, this problem would of occured anyway it would of taken a while longer and then you would of heard noise from rear wheels but it happened sooner due to removing the rotors, its not there fault but they should of called you and told you that you would need parking brake shoes but thought that you may not use the parking brake which is a bad thought in there part. maybe its just an adjustment that need to be made to the parking brake. heres a picture of the rear shoes to show you the metal bracket the shoes come apart from. another thing is that if the rotors were replaced then that explains it more as the old rotors contain rust and build up and that helped make the parking hold bettter.lets hope it just an adjustment.johnjohn2_137.gif
How to readjust the emergency brake handle
theese have a "piece of junk" cam action that rusts solid in a few years. If the parking brake is depressed at the wrong time the cam will lock the parking brake shoes against the drum and take the drum and brakes shoes out. Since the drum and rotor are a one piece combo, you will have a nice repair bill. Probably need to take the unit
apart every 20K or so, clean it up and lube the cam levers. My truck had less than 20K on in when I found the cam levers rusted together so solidly that I had to hammer them
apart. I painted my parts with galvanize paint and then lubed the pivot point with anti-seize. In answer to this question of adjustment, on these trucks, there is an adjustment spool similar to those used in the standard drum brake systems. It can be
accessed from the back side of the drum cover through a plugged hole also the same as a standard drum brake system.
1helpful
2answers
1997 Ford contour rear brake shoe replacment help.
Brake shoe removel:
Depress and turn the retainers for the hold-down springs and pins to remove them from each shoe. Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Step 4 Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
  • Step 5 Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xgUqun
  • Step 3 Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xdByQ8
  • Step 2 Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xVyUAt
    2answers
    Parking brake on my 01 kia rio(standard) no longer holds
    parking brakes are adjusted at and with the rear brakes,..(drum brakes that is),.....as you adjust the rear brakes to have a slight drag as you spin tire, the parking brake is adjusted at the same time,...they work together with that one adjuster,....as you pull on the parking brake, it makes the brake shoes spread apart just as they do when you push the brake peddle,..by adjusting the rears you'll also find that the brake peddle feels better too.
    2helpful
    I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
    Drum, Rear Brake System Standard Rear Brake
    Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
    Heavy Duty Rear Brake
    Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
    The rear drum brakes:
    • Have internal shoes that expand against the brake drum (1126).
    • Are a single-anchor type.
    • Are actuated by one rear wheel cylinder (2262).
    • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
    • Adjust rear brake shoes and linings (2200) automatically.
    • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
    When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
    The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
    1helpful
    2answers
    2004 buick emergency brake
    This car has regular shoes on the back not disc. Replace shoes and adjust cable. No parking brake is a sign of worn out shoes. Regals have rear disc on them for this year.
    Top Dodge Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Dodge Expert? Answer questions, earn points and help others
