Computers & Internet Logo
Posted on Aug 24, 2010
Everytime i run kindergarten jumpstart I get a atlas runtime error...what's up with that??
1helpful
How can I fix the runtime error I'm having on jumpstart 3rd grade on my windows xp?
Recommendation:
* Right-click on My Computer, then left-click on Properties.
* Left-click the Advanced tab at the top.
* Click the Settings button under the Performance heading.
* Click the Advanced tab at the top.
* Click the Change button to change the virtual memory.
* Write down the numbers that are currently set.
* Change the initial size to 512.
* Click the Set button.
* If you are asked to reboot, say Yes.
* If you're not asked to reboot, click OK on each window to get all the way back to your desktop, and then reboot your machine.
* When the computer restarts, try the game.
If the game fails to run and gives you the same error, please follow the instructions above and set the initial size to 256. Reboot the machine and try the program again.
As a last resort set the virtual memory to a large number such as 4000 or more and then try the program after rebooting. If this works you can drop the virtual memory by small increments until the error reappears then re-set it to the last good number.
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
2helpful
How to delete names on Jump Start Advanced 1st grade?
The Knowledge Adventure page makes this suggestion:
Recommendations:
· JumpStart: Most of the JumpStart programs have a keystroke combination like CTRL+D+D to delete one user at a time from the sign in screen. See the manual for more information regarding the software. Other JumpStart programs have a delete button directly on the sign in screen.
CTRL+D+D didn't work for me on JumpStart Kindergarten, but CTRL+ Delete did!
Runtime errors
re install and try it!!!!!!
Runtime error on act of war
Reinstall it and
be sure that your VGA card chipset supports for that game
2helpful
Runtime error video cam suite 1.0 panasonic
try downloading update from this site it worked for me its:-
www2.panasonic.com/Consumer-electronics/support/Drivers-and-Downloads/list-75489-Camcorders - 301k -
click on the panasonic video cam download
3answers
Error messages. which cause my computer to crash.
what is your operating system?
what is internet explorer version?
if you answer these 2 questions I maybe able to help you resolve your problem
Top Jump Start Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Jump Start Computer and Internet Expert? Answer questions, earn points and help others
