Sister from Canada sent me a gift of blackberry pearl 8100 here in the Philippines. The BB Pearl is locked to provider Rogers of Canada. Need to have it unlocked so can use it here with local sim card. Need a free unlock software that can generate unlock code from the phone's IMEI no.
Option # 3: T-Mobile or Cingular, your carrier
Yes, you can ask your carrier for an unlock code for your Blackberry and guess what, they do it for it Absolutely FREE. So, what is the catch? The only condition which atleast T-Mobile imposes on its customers before it gives out the unlock codes for the Blackberry Pearl or any other cell phone is that you have to be under the contract for atleast 90 days or 3 months before they can give you the unlock code. So, if you have the patience, I would recommend that you wait for this 3 month time frame before calling up 611 from your T-Mobile phone, talk to customer service and get your unlock codes.
In my search for the Blackberry Unlock codes, I found out that a lot of people mess up before they have no idea how to enter the unlock codes correctly. So, follow this method to enter your Blackberry Unlock code
How To Enter the Unlock Codes on a BlackBerry Cell Phone
Model : All BlackBerry Models (except T-mobile)
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Model : T-mobile BlackBerry Models
1 - On the Home screen, click the Tools icon. The Options screen appears.
2 - In the tools screen, select the Settings icon.
3 - Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 - Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 - Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 - Input the Network Unlock code
7 - Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 - Input the SIM Unlock code
7 - Press in the trackball in once
Your phone is unlocked
For everyone who is about to unlock your phone. Please don’t go for free code and unlock code generators. Most of these codes won't work and this will reduce your chances to unlock your phone. Always go for some trusted websites. Pay some dollars and get the original codes. I got my code form UnlockGenie.com http://unlockgenie.com/)
I got my code instantly and I unlocked my phone without any trouble. :-)
Type in *#06#
I've been dealing with the same issue, trying to find the MEP code- or more specifically- find a calculator application which uses the IMEI to get it. One does exsist but you have to pay for that as well. The simplest solution and the one that absolutely will be free: follow the instructions above to get to the MEP code screen, call customer care for the provider of the phone (this unit was ATT). Select the options that get you to a technical support rep. w/o entering in any info. Tell them you are about to travel to the United Kindom and you currently have NEXTEL as a service provider which doesn't use sim cards and wont work in the U.K. Tell them you have this (your blackberry) phone and you just need it unlocked so that you can use it there. They will give it to you. That's exactly how I just got mine. Cheers!
It's a clear and fully detailed guide on how to unlock a BlackBerry pearl :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
It's a clear and fully detailed guide on how to unlock BlackBerry Pearl :
3. Go to Options
5. Select SIM Card
8. Type MEP2 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter network mep code
11. Enter the code ( you should see "code accepted" )
All done.
To unlock your phone you will need to enter the code. This code is just a calculation of IMEI number of your phone. To find your phones IMEI number -type *#06# into your phone or look under the phone battery.
There are different online services that will calculate the unlock code for your IMEI number.
I can recommend this one (cheap and reliable).
Click here to unlock your Blackberry Pearl 8100
Note: don't share your IMEI number on free forums like this.
Just got my code. THANK YOU !!!!
Link above is for unlocking.com, site says unlocking code in 30 seconds and lists their typical time in seconds over the last 90 days...... so, based on this site and responses, I paid for an unlock code. After 15 minutes I thought, what the heck is taking so long and did a little google search, it seems their reputation is suspect.... do your own diligence.
Each phone has it's own individual unlock code which you can get free from the provider!!! Tell them you are going to a foreign country and want to use a local service.
THAT IS THE ONLY FREE WAY TO UNLOCK IT!!
Go to these website.. very efficient no payment neede. absolutely free. just share them on fb or tweeter if you like
here is the link guys: http://www.unlockcodeforblackberry.com/
kudus
No one provide you free unlock code. If anyone provides some codes and that code does not work then your phone will permanently locked. Codes generate from server based on your IMEI so nobody will give you free.
There can be many ways to get your unlock code. If your contract period is complete you can ask your cellular operator for the unlock code. But, they do make it very difficult for you to get the code.
You can also visit Unlockgenie.com and can see different options there to get unlock code for a price. Choose any price appropriate for you.
Hope this helps you better
I need blackberry pearl 8100 mep code
Unlocking by code is also a great alternative see http://www.mobile-unlock.net
You get the unlock code from your service provider
Hi all
To unlock your phone you must provide not only the IMEI but also the Mep.
If you don't have, this is a small tutorial video i will show you How to unlocking your Blackberry cell phones using
Blackberry Unlock Code Generator
http://www.youtube.com/watch?v=Ur_PJy3qNfw&feature=plcp
if your cellphone is not supported Read the topics in our website ( unlocking cellphones ) Related to Blackberry phones
After that use the [URL="http://www.unlockingcellphones.net/2012/03/how-to-unlock-blackberry.html"]blackberry code calculator[/URL] to generate the code.
Good luck.
No one will give you blackberry pearl 8100 unlock code software and by the way free unlock code is not too good for your phone since can damaged your phone if you got wrong unlock code. My suggestion is purchased blackberry unlock code for small price at third party sites rahter than trial error with free unlock code.
Unlock your blackberry instant - get the unlocking codes for your blackberry to your mail...
You can find unlocking instructions and all those services for a cheap price on blackberry unlocking
Yes ofcourse i have BB 8100 pearl ... wanted to unlock n i did it from unlockgenie ... n it worked ... try
check this page for more info
So after you unlock your phone from rogers , can you switch your phone to a different service like telus?
Each phone has it's own individual unlock code, so no one is going to post a code that you can use on here, and the code they may have used for there phone WILL NOT work for yours, so stop asking.
Th cheapest company to use is Unlockdata, and they have a section their site dedicated to the Blackberry Pearl
http://www.unlockdata.co.uk/manufacturer.asp?m=BlackBerry-Pearl-Unlocking&man=BlackBerry-Unlocking
I cant brows internet in my black berry 8100 handheld.please help me to solv this.it bought from usa and i m in bangladesh near of india.
How are you?
Our company supply Xsim unlock sim card and iphone 3G unlock sim card from China.
The best price of the Xsim unlock sim card is US$3.50/pc
And the quotation of Iphone 3G unlock sim card is US$4.80/pc
All above quotation are CIF your Side,
Look forward to your further reply.
Best regards.
Barry Xu
Digisk International Co.,Ltd.
Room 605.Lianfa Building,Futian District,
Shenzhen,China.
Tel:+86-755-81167879
Fax:+86-755-83276467
Mobile:+86-13715224648
Website:www.digisk.com
Msn:[email protected]
Skype:Digiskbarry
SOURCE: free unlock of blackberry pearl 8100
My brother send me a BlackBerry pearl 8100
when I insert a SIM card phone displayed invalid sim card.
I want some free software for bangladeshi people
To get the unlock code, mail or call ur service provider(Rogers) requesting for the unlock code i.e from where u have brought the handset.After receiving the unlock code follow the bellow mentioned steps:
i need to unlock my att blackberry phone to tmobile, can u please help me and email me thank you.
I am located in nigeria and my uncle send a blackberry 8100 from T Mobile network to me from UK and i needed an unlocking code so as to use it with my local network in Nigeria here. kindly mail the unlocking code to my e-mail address. [email protected]
Thank you.
Received a Blackberry Pearl 8100 as a gift and is locked to Cellular One provider. Does anyone have a free or inexpensive unlock code? Please help!
anyone have a free solution to unlocking my BB8800 [email protected]
cannot use other local sim cards
What is the unlock code for the Blackberry Pearl Red from AT&T?
blackbeery perl 8100 unlock AT&T
i need an unlock code for my bb pearl from at&t and the steps to do it..
I am in Bangladesh. My friend sent me a mobile phone, but I can’t open it due to lock system of T-mobile of USA. I saw that you require some money to break the lock system, but there is no appropriate system to send you the money from Bangladesh. I request you to send me the unlock code, if possible. The particulars are given below:
Phone model : Blackberry 8100 pearl
Service Provider : T-Mobile, USA
IMEI number : 357838.01.200923.1
Hi! I bought a BB Pearl 8100 from the US and its locked under TMobile. I'm sending it to my friend in the Philippines. Can you help in the unlocking of the BB Pearl?
i need an unlock code for the blackberry pearl 8100.... its locked to a cell one provider
Dear service officer,
I am a Airtel cutomer . Due to my personal reasons I have to move out of my current location Pune to other country. I don't want to pay the heavy roaming chareges while being outside India.
For the above mentioned reason, I am requesting you to give me the SIM unlocking password for my below mentioned Balckberry 8100 Mobile:
PIN: 251613B4
IMEI : 356920018955970
I look forward for an immediate reply from you.
Kind regards,
Prateek Dawada.
Surfray, did yah get anyone here in the Phil to unlcock your BB pearl?
I'm also her in the PHIL and my aunt sent me her BB 8100 but locked with At&t.
Need to unlock
i have the same problem as well... is it possible that i could get the unlock code for free? my BB pearl 8100 is locked to T mobile and it was given to me as a gift, i cannot use it here in the Philippines. I hope you will be able to help me out. Please notify me if you have the unlock code, Thanks!
Please email me.
Lynn
I also have the same problem. My bb is of vodafone spain.
sim not being accepted
pls i have a blackberry pearl 8100 and is using only sim pls can u help me with a free softwere to unlock it pls am beging for it.
am stephen
i got a bb pearl 8100 given by my niece from US. It is currently locked to cingular. I want to use it here in the philippines. please help.
hey,i got a black berry pearl 8100.and it is locked.it wants a country code.plz get me out of dis prob
my brother sent me a t-mobie blackberry 8100 from USA. I am in Nepal n want to use local sim. I cant as it is locked. I want to unlock it for free.IMEI-357839012376075
pin-241BAD53
I have a blackberry 8100 from my co worker who got it from this guy who lived in another country or something and i want to be able to unlock the sim so that i can use my tmobile sim card in the hand set
need my at&t blackberry pearl 8100 imei no: 355768016706379 so i can use it with my t-mobile service
I have AT&T Blackberry pearl and want to use it oversee. The local sim is not active. So i need free unlock code to use my phone with local GSM provider.
THANKS
same prob
I Have a At&T Blackberry Pearl 8100 and don't know how to get it unlock to use it for T-Moblie services....Can you help me?
Email me please.
Pls help
i need to find a software so can generate an unlock code using imei for free
from saudia arabia i got BB Pearl 8100 but i cannot use it in lahore pakistan because of country codes or some sim blockers.......
i just buy blackberry 8100 but i can not use because i do no unlock code so pleas help me to use my mobile.
think you.
My friend sent me a BB 8100 from states about two and half years ago. Since then I've had it with me. So If there is any one who can help me (give I) the ulock code, I would appreciate U.IMIE no. 352127.01.637502.9
PLEASE and
Thanks
I need an unlock code for my blackberry 8100 phone, and I have ht eIMEI #. How can I get one free or nearly free?
i got the unlock code from t-mobile but i am not able to carry out the steps to unlock correctly.i was using in US and now i want to use in India(airtel connection)
i have a bb 8100 i have it country locked being sent by someone from london
i want to use it with local sim!
can ya help????
a friend gave me a black berry pearl 8100 but its from cingular and i want to unlock cause i have tmobile
i have a blackberry pearl for cingular and i need a unlock code for t-mobile
who do i unlock my t-mobil pearl 8100
hi my uncle send me a gsm blackberry pearl 8100 from usa,but set is country locked and i would like use it in bangladesh by using local sim card,please help me out
unlock me my at&t bb pearl, b'ze i changed my residence country
IMEI: 355767.01.459741.8
i am having blackberry pearl 8100 i wanto to unlock the the is from london
plzz send me the detail for unlock the phone
i have the same problem, please may i have the code
i bought a blackberry pearl 8100 off ebay and it came from england and its locked to there and on vodafone. can i get the unlock code please??
I have Black Berry 8100 perl phone and it is locked. so if there is a way to unlock it free of charge please tell me.
I cant unlock my phone ( blackberry pearl 8100)
i have the
RIM BlackBerry Pearl 8100 and i need to unlock it...for free..can u please help me?
how do i unlock my 81oo
my mother buy the black berry for me on T-mobile, and me I don't have T-Mobile in Haiti. What should I do? I can't do nothing. The phone always tell me sim card invalid.
have a t mobile phone.....blackberry 8100....they wont help they claim I owe them money....not true......but I have att and would like to use it with my att....please help
i have a blackberry pearl that was with the cellular one service and recently i got an at&t sim. can you please help me unlock it
need to unlock a blackberry 8100 cell phone
what is the blackberry 8100 imei code
2 steps up to now, need unlock code
I also got a blackberry 8100 that is locked to t-Mobile, anyone can unlock it so that i can use with the local network in jamaica.
i had the same problem so i went onto the website of the provider it was locked to and gave them my imei and payed 14 sterling to them because it was vodafone england and the next day they sent me the code..
how can i unlock bbpear8100 locked wit at&t mobile?
i am a nigerian with the same problem , pls help us out.
thnks
rogers blackerry pearl 8100
unlock code for blackberry pearl 8100
the same problem. need assistance
brother from Canada sent me a gift of blackberry pearl 8100 here in the Philippines. The BB Pearl is locked to provider Rogers of Canada. Need to have it unlocked so can use it here with local sim card. Need a free unlock software that can generate unlock code from the phone's IMEI no.
To Whom It May Concern.
I'm a Nigeria and my brother send me a vodafone blackberry pearl 8100 from spain but it was locked with the service provider. The Manual was in spanish language and I can't read it.
Please assist me to unlock it so that I can use it with our gsm network here in Nigeria.
Thanks
IFEOMA
Nigeria.
how to unlock
my sister gave me a phone from uk. how can i use it with my Bangladeshi SIM in Bangladesh ?
need the unlock code too
my freind
iam not taken any steps to unlock
need to unlock BB Pearl 8100.
my cousin send me black berry pearl 8100 but in pakistan not working so i want to know how it work in pakistan
i have blackberry 8100 its from canada my bro sent me and its locked i want to unlocked this phone plz send me mep code
cannot get it on any network
I'm looking for a free code to unlock my blackberry pearl 8100.
I need to find a free code to unlock my blackberry pearl 8100. My IMEI is 352127.01.591994.2
how can i use my blacberry pearl 8100 here in the philippines. please give me solution step by step so i can use it using globe sim or smart sim. thanks!
same pro
sim unloker
need my blackberry to be unlocked so that i can use it when i travel to another country
I have the same problem, need unlock code. I canl't get it from sp.
got a blackberry pearl from a friend and it needs to be unlocked so i can use at&t
i have same problem dad died i inherited phone but cant use it .
I have a blackberry from my sister, and the #7 key is actually locked, I guess. When I try to call a number with 7 in it, it shows up * instead of a 7, could someone please assist me?
Yes;I have the same problem.
Yes,I have the same problem
i just dont which BB i send to my brother in Philippines if i coul remember it looks like 6320?, and he said , it was unlock i forgot the pin #.. can they still use it and what service provider is available.. Thnak you same problem
The BB Pearl is locked to provider Mobilink of Pakistan. Need to have it unlocked so can use it here with other local sim card. Need a free unlock software that can generate unlock code from the phone's IMEI no.
my cuzzin sent me a bb pearl to but ineed to unlock it cuz he thought i still had t-mobile but i had switched to att
i need  unlock code for my blackberry 8100
YES I HAVE SAME PROBLEM
I bought an BB 8100 originnaly from T-mobile and i need help to get the code to unlock it.
TKU
i need unlockcode for pearl 8100 imei is 355768013556124
i have a bb pearl 8100 t-mobile from US i'm now in Germany I need to unlock it but don't don't have money to buy the unlock codes online for 70 bucks
My mom from US send me blackberry pearl 8100 lock to T-Mobile i wanna use it here in Australia can u help me to unlocked the mobile pls
hi, my brother send me 8100 pearl from spain but i cant use it in pakistan because i cant get its country code,soo plz help me.
How do you calculate the unloack code using the IME number ?
Have blackberry 8120 and want to unlock to use different SIM.
I need the BlackBerry 8100 pearl unlocking code
i need a tmoblie 8100 unlocked so i can use it with a att sim card
i did all your stuff and it still aint unlocked
My daughter got a blackberry pearl off eBay and wants to give it to me, unfortunately, the blackberry is t-mobile and I'm on at&t. The imei number is 356920.01.485737.8
I have t-mobile and my friend gave my a brackberry pearl for at&t what is the unlock code please help
my cuzin gave me a blackberry pearl 8100, which is on the network At&t, but i live in trinidad, and i need a free unlock code to unlock it.
unlock
unlocking pearl
somebody gave me a blackberry for christmas but its lock with tmobile, im so sad i cant use the phone here in the philippines. Please help me, it would be the best gift for christmas...
thanks
i have a blackberry pearl 8100 i bought on ebay. its locked to at & t, but I have Cincinnati Bell. I stopped at Cincinnati Bell store & they confirmed it was locked. Does anyone know how I can get a code to unlock for free?
i need a t mobile unlock code for a blackberry pearl to go from t mobile to cingular
red blackberry pearl 8100- tmobile
I got this phone as a gift and i need to hook it up with another provider
my sister sended me a phone
Trying to unlock a Blackberry 8120
i need to change provider
same problem in spain with movistar need to unlock it bbery 8100 pearl
i'm tryin to get a unlock code for a blackberry pearl free please help i have all the other information except the code
im tryin to get my phoned hooked up with the service provider in my country so as to get a free offer they hav goin on with blackberry phones..however wen i try signing up, the service provider in my country says my phoned cant get the service because my imei is already registered to another service provider so i need to hav it changed before being able to access it! so i cant add or give out my pin to friends who hav bb because of the imei!
need unlock code for my black berry 8100
i need to unlock my black berry pearl which my brother sent to me here in Philippines.
i want to change the provider FREE you always have to pay ARGH!!!
hi i have a blackberry and need to get it unlocked please help has anyone got unlocking code for same thanks
i need to unlock my 8120 for tmobile but it costs to much money.
I have a blackberry 8100 and i needde unlock code
I need a free code.
the blackberry 8100 was given to me by my sister and i wan to unlock the phone to use on a different network without any extra charges is there a way????
i forgot my password and i tried to remember and i keeped tring and now it has a white sceen with something in the middle and the numbers 507
need unlock code for blackberry pearl
I need help with this too i need to convert it into a prepaid to use out of town....
same
need unlock code
i don't know my network mep number
i need help code of blackberry 8100
free unlocking.
I was also sent a Blackberry pearl from Canada and it was locked for the Rogers network now I need to have an unlock code so that I can use my AT&T sim card How do I go about doing something like this?
I need to unlock my blackberry pearl 8100 I know how to do it I just need the code specific to my phone I know that I can get it from global unlock for like $2.00 but I dont want to spend anything is there any way I can get it for free I wont give up!!
dear sir ,
i have a vodafone black berry 8100 perl but icant use any other sim card so please request to you please send me unlock code for 354879.01.897919.4
can anyone give me a code for my bb 8100
i have bb phone in the philipines and i dont now the code can u pls pls give me the code
How can i unlock my t-mobile blackberry pearl to cingular for free?
I have a Blackberry Pearl 8100 from Vodafone UK and I want to insert my UAE SIM card. How do I unlock the device
can we get these unlock codes from the phone itself?
MY HANDSET BLACKBARRY NO OPEN SERVER PLEASE HELP ME
BLACKBARRY HAND SET EMEI NO 355767015502466,NO NETWORK OPEN IN INDIA PLEASE HELP AND REPLY FAST
imei no 355767015502466
blackbarry 8100 atst mobile usa open in india lock code
MY MOBIL BLACK BERRY IMEI NO 355767015502466 PLEASE HELP MY MEP CODE THANK YOU
