Thanks. Ok, the only part that is of importance will be the actual analog pressure sensor switch. You will only need to replace this part. This part fails in most duet sport(Steamers) models of this nature. It is mounted just next to the Electronic board that is located and mounted on the inside of the washer cabinet. The drum must be removed to access it and the top/front panel, as well. I will post the links to the diagram and part number for the part, below. The actual part that will need to be replace will be labeled number 20 on the diagram provided below.
Exploded Diagram
Analog pressure sensor switch part number -W10156252
Testimonial: "Thanks you have been very helpfull"
Correction:
You may be able to access the switch by just simply removing the rear access cover. This switch is very close to the rear access cover(Top Left Corner When Facing the rear of the unit). Try to reach it that way. It may not be necessary to disassemble the entire unit.
Actually it is acessible from just removing the top of the washer. Thanks
This should be possible, as well. I would remove the top and rear access panel to insure proper working space.
Good deal; I'll update my notes to reflect that replacement procedure.
There are no f-35 codes for the duet series washer....
Yes there are f 35 codes on the duet steam washer.. the service buletin in the lower compartment of the washer says that it is a analog pressure sensor failure or any malfunction of the steamer component.. even if we don't use the steam function, it makes the washer shut down
i am wondering ifit is just a bad circuit board?
I see. You didn't post a valid model number so i couldn't actually tell which unit you had. Ok, what is your model number?
I need the entire model number so I can post the correct part number. it is not the CCU. That is ok. No issues there...
it is the WFW9500TW01 model #
serial # CSW1609372
i just removed the part in under 5 minutes by taking the top off only. It is tucked right under the top of the washer on the right hand side if you are facing the front. No need to remove the rear panel at all, there is more than enough space to do what you need to do from the top
