The meter will not indicate anything until you have the charger plugged in and will move to zero when fully charged Hopes this helps you
I'm sorry, I forgot to say that my chair was indeed plugged in.
Well then probably the charger is not working. With a Pride Chair the on-board charger lite will only come on when the batteries are fully charged You have to bend down and look at the rear of the chair underneath to find the light on the charger. Now if you have a volt meter you can check the battery voltage through the joystick charger port. place the leads in the two outter plug holes and read the voltage. After a full charge the batteries should read 24-26 volts and if the charger is plugged in it can read up to 30 voltsif there is no change between charging and not charging then the charger is bad. You might also check that the wires going to the meter are not unplugged. Hope this can help
Thank you, this was indeed helpful.
