Cobra 148 GTL 120-Channels Base CB Radio Logo
Posted on Aug 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a general lee and I am running a 2 by 8 box. What should I turn my radio down too to run this box I was told 3 watts wgat do I turn to accomplish this I doesn't seem to have much modulation either
Radio-tech155
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Jul 06, 2015
Radio-tech155
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
18756
Points
46
A 2x8 has a variable on the front.. Leave your radio alone.. Adjust your deadkey to 200watts let it swing
  • Radio-tech155 Jul 06, 2015
    A 2x8 has a variable on the front.. Leave your radio alone.. Adjust your deadkey on the amp variable to 200watts let it swing.. Loaf it along.. Dont ruin your equipment
Anonymous
Level 3:
Guru:
  • Master 773 Answers
  • Posted on Aug 25, 2010
Anonymous
Master
Level 3:
Guru:
Answers
773
Questions
0
Helped
268890
Points
1659
The radio needs to be tuned for the box. 3 watts sounds too high for a 2x8.
I would say it would be more like 1-1/5 to 2 watts. That may be why your not getting that much swing.
You should set the radio so the box dead keys around 300 to 400 watts.
How to pick / turn and what pods to set
first you need a schematic,then an alignment diagram,then a block diagram, then a scope, a signal generator a dummy load, a watt meter, a sinad meter,and then a manual showing what to turn and what it does and you have to turn them in order. such as l1,l2,l3,
1helpful
General Lee has no AM RX
Replace C17 also ck/Replace FL1 455 IF filter
General lee cb gets hot and stops transmitting and receiving.
Connex general lee - Mauldroppers CB Radio Forum
www.mauldroppers.com > Citizens Band Radio > Mobile DiscussionOct 23, 2012 - 13 posts - ‎7 authors Thread: Connex general lee ... amps and is getting cookin' hot when key'd for as little as 30 seconds, lol, truckstop hack job comes to mind lol.
What watt dead key and swing on CONNEX 3300 HP
A standard 3300 hp I seen get up to 40 watts peak,
normally I would turn the audio pot up all the way never snip anything and deadkey down to 2 watts. Than adjust for forward swing, I also never run a pwr mic. Good luck
2answers
Wanting to know how to peak and tune my general lee hp cb radio
if you don't know how don't do it .If you turn the wrong pot you could kiss that radio goodbye.Find a tech and let them do it.
I need a wiring diagram for the jensen lxa400. Pushing 2 kenwood 6x9 (200 watt rms each) and 2 dual voice coil 12's (300 watt rms each) in a truck box. Everything is 4 ohm. Thanks, Curtis
you shouldn't need a diagram all you need is these items here.
purchase a 4gauge wiring kit
run a a power line from battery to amp with a in line fuse 6in from battery.
run a ground from car frame to amp. ( scratch paint and screw it down with an eyelet for good contact)
run a remote from radio to amp.(blue wire)
run rca's from the radio to the amp ( sub input on back of radio)
finally connect your speakers.
Modulation with my linear
the radio you are trying to fry your amp with is driving the amp to hard. that radio has a toshiba 80 watt final inside the radio you are killing your radio with the dead key at 2 watts it causes the final to overheat and shut down because it is not built to be turned down that much. its best to turn the radio back up and use the radio.
I HAVE A 2517 GALAXY RADIO IT IS MUFFELD ON TRANSMIT
What is the power output on a watt meter telling you? if it is up above an 8 watt dead key with the rf power turned all the way down, someone has turned up the radio inside and you will ned to turn it back inside to get about a 2 or 3 watt dead key with the rf power turned all the way down on the outside knob on the face of the radio. to do this, you will need to locate the VR18 pot for low power on am/fm and the VR14 pot for high power on am/fm and adjust accordingly, you are most likely overdriving the radio in some way and if you are not familiar doing this sort of thing, then my suggestion would be for you to take it to your nearest electronics repair tech and have them do it for you. It is not a costly procedure and you will be better off to have an experienced tech in there. Also if you are running a power mic on it, try turning it down some or going back to the stock mic to see if the problem persists. If it does while running the stock mic, then most likely it's internal issues like the one explained above.
2answers
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
