Hi i'm trying to login into the b6200 oki thru the web interface. it asks for login details. I have the password (my password is ' 1 ', and i'm not sure if I should include the trailing zeroes?) Plus i'm not sure what the username should be, ' admin ' perhaps?
Thanks
It's essential to ensure that you enter the correct login details to access the web interface of your OKI B6200. Here's what you should do:
Username: The default username for many network devices, including printers, is often "admin." So, yes, try using "admin" as the username.
Password: If your password is '1' (without the quotes), you should enter it exactly as it is. In this case, you don't need to include trailing zeroes.
So, your login details should be:
Username: admin
Password: 1
Please note that if you have previously changed your password or if your network administrator has set up different login credentials for your OKI B6200, you should use those credentials instead. If you're unsure about your login information, you may want to check with your network administrator or refer to the device's documentation for any customized login details.
Log in as root (lower case) and put last 6 digits of mac address in uppercase as password.
