Sony Playstation 3 (PS3) Console Logo
Posted on Aug 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn my PS3 on the startup screen comes up but the user names do not which means I can't play any of my games what should I do?
dennythedon3003
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Sony Expert 159 Answers
  • Posted on Nov 30, 2018
dennythedon3003
Sony Expert
Level 2:
New Friend:
Greenhorn:
Answers
159
Questions
0
Helped
58991
Points
486
Customer care helpline NUMBER +1-^833_^272-^O777,,,,,,,CALL THEM
If you are having trouble with your games freezing it is possible that you have corrupted data on the PS3 hard drive. The link below will take you through resetting the drive
Anonymous
Level 2:
  • Expert 277 Answers
  • Posted on Aug 24, 2010
Anonymous
Expert
Level 2:
Answers
277
Questions
0
Helped
62189
Points
953
Hello,<br /><br />You can also try the steps below. Its from PlayStation Forum:<br /><br />1. Turn off Playstation&reg;3.<br />2. Hold the power button down; the system will turn on and turn off once again.<br />3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps<br />4. When you hear the 2 beeps take finger off power button.<br />5. You will be prompted to plug in your controller via USB and then hit the PS button<br />6. The Recovery menu will pop up.<br /><br />The current Recovery Menu supports:<br />&bull; Restart System: Restarts the PLAYSTATION&reg;3 System.<br />&bull; Restore Default Settings: Reset all system settings back to default.<br />&bull; Restore File System: Checks for corrupt/missing system files.<br />&bull; Rebuild Database: Rebuilds the OS for the PLAYSTATION&reg;3.<br />&bull; Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.<br />&bull; System Update: Update the PLAYSTATION&reg;3 System<br /><br />If the above steps still does not solve the problem, then I think will have to update your Ps3.<br /><br />Update your PS3 (in the settings menu the 1st option).<br /><br />Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as<br />well as cookies.<br /><br />You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with<br />your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.<br /><br />But if your problem is not still solved, then maybe you should call sony for further assistance.<br /><br /><br />If you are having trouble with your games freezing it is possible that you have corrupted data on the PS3 hard drive. The link below will take you through resetting the drive.<br /><br />http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive<br /><br />If you still have trouble it is possible that you are having trouble with the PS3 system its self.<br /><br />Take care.<br /> <br /><br /><br />
1helpful
My screen come's on but the startup wont come up but my users and stuff like game video images and settings wont appear up (contents page) ie: no video game online acess its just a blank screen with the...
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
2answers
I CAN'T SIGN IN TO PLAY STAITION NETWORK ERROR CODE (80710092)
ERROR CODE (80710092) can mean incorrect password, incorrect user name or bad internet connection check your user name and password and if that doesn't work then disconnect your ps3 from the internet and then reconnect
1helpful
My sons PS3 console keeps coming up with an error code - 80010017 . . . saying that an error has occured . . . what is this problem . Ta .
There is already a solution by a User :-
Got home, downloaded flow on the new PS3 and tried to play, just before the game launches, the screen returns to XMB with this error: "There is an error During Startup (80010017)"... But I did Active my new PS3... So I went back into Account Management ([Friends] [Account Management]), de-activated and activated again, PROBLEM RESOVLED. Seems like the machine isn't happy with activation before download, I guess.
If problem still persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
4helpful
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
2helpful
When i turn my ps3 on it only shows the background. no users.
Hi, this sounds like a problem with your hard drive booting up. This seems to happen alot with the PS3s. Try taking the hard drive out and putting it in another PS3 and see if it does the same thing. If it does then your hard drive is damaged and needs replaced.
Starting up Problems
I found it 2 min. ago. Ok here: while your ps3 is on hold the power button on the ps3 for you will hear one beep, keep holding it then when you hear the second beep take your finger off. Your ps3 should turn off. Now push the power button while holding your finger on it again, you will hear two single beeps, then a double beep, let your finger ago and a screen should appear with six options. Chose something like reset(or restore) file data or something like that and click yes, this wont do anything to your game/music/movie/etc. files but now your ps3 shall work.
Playing PS3 games from the Hard Disk.
You mean like psp play like you can do for Chains of olympus? You just plug in the psp and go to your user file and set it to auto login and just log in and out fromt he user profile then go to the menu that has psp play
Ps3 wont work
see if you unit overheating
Online name on ps3
You would have to make a new user and copy all the files from the old user delete the old user and make a new online accont
PS3 wont take any GAMES nor DVDs
I have been playing today and just gone back on and not one game will load
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
