2000 Lincoln Town Car Logo
Posted on Aug 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing a coil cylinder #2 need firing order
Anonymous
Level 3:
Guru:
  • Master 630 Answers
  • Posted on Aug 24, 2010
Anonymous
Master
Level 3:
Guru:
Answers
630
Questions
0
Helped
301316
Points
1797
1-3-7-2-6-5-4-8
Coil On Plug ( C.O.P. ) ignition system
The engine cylinder / spark plug locations are numbered :
firewall
4 - 8
3 - 7
2 - 6
1 - 5
front
( on your 4.6/5.0/5.8/ liter V8 engine ) changing a coil cylinder #2 - ford_cyln_1234.gif
Rotor Under Cap Spins:
Counter
Clockwise
1.4 L VW Jetta cylinder firing order??????
Here is the firing order below, but you made a grave mistake. You are subscribing to the "let's try replacing this" method of car repair which doesn't work and costs $160. What if it is two $10 spark plugs causing the misfire?
So what you do is remove the plugs from cylinders 2 and 3 and check them for condition and gap. Clean with a wire brush, gap and replace. Is the misfire still there? If it isn't, you have fixed it for free. If the misfire is still there, you take the coil from 2 and swap it with cylinder 1. Does the misfire move to 1? If it does, the coil needs changing. Swap coils 3 and 4 and do the same test.
https://www.google.com/search?q=VW+Jetta+cylinder+firing+order
My 2004 Pontiac Aztec/rally has a different firing order stamped om the coil packs. They are from left to right standing in front of car they are 523641. Why am I getting different order?
This is not the firing order that is stamped on the coil packs.
Coils are matched by 2 pairs of cylinders for ignition spark plugs and coils system.
1- Like 5 2 and 3 6 and 4 1
2- Pairs of 2 cylinders are firing at the same time.
3- When cylinder number 5 fire at ( Power Cycle) the cylinder number 2 fire but in ( Exhaust Cycle ). That is why you have those number stamped on the coil packs.
Hope it helps.
1helpful
3answers
Can you tell me what the firing order is when looking at the motor of a 2005 GMC Envoy SLT 4.2?
Firing order is 1, 5, 3, 6, 2, 4. Number 1 cylinder is up front. Why would you need the firing order, this engine does not have plug wires, each plug has its own coil pack, each coil pack is controlled by the computer.
4helpful
2answers
Need to know spak plug firing order for a 1996 pontiac grand am
4-cylinder:
Firing Order: 1-3-4-2
3.1 liter:
Firing Order: 1-2-3-4-5-6
1helpful
4answers
I need to know what the cylinder # are and what the fireing order is
In the 4 cylinder the firing order is 1,3,4,2 and the cylinders are numbered 1,2,3,4 from the Passenger side to the drivers side.
In a V6 the firing order is 1,6,5,4,3,2 and the cylinders are numbered 1,3,5 in the front from the passenger side to the drivers side and 2,4,6 in the back from the passengers side to the drivers side.
4helpful
3answers
Yes i have a 96 chevy lumina i changed the plugs and i think i may have switch the wires but dont know where they go directly
From standing in front of car and facing engine:
3.1L and 3.4L OHV V-6: The cylinder location is from left to right (rear cylinders) 1,3,5
(front cylinders)2,4,6
The coil terminals from left to right: 5,2,3,6,4,1
Firing order 1,2,3,4,5,6
3.4L DOHC V-6: The cylinder location is from left to right (rear) 1,3,5 (front) 2,4,6
The coil terminals are from front to rear 5,2,3,6,4,1
The firing order 1,2,3,4,5,6
3.8L V-6 cylinders left to right (rear)2,4,6 (front) 1,3,5
coil terminals front to rear 1,4,5,2,3,6
firing order 1,6,5,4,3,2
8helpful
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Firing order need to know what plug is number 1 and what plug on coil pack is number 1
For the 1993 Chevy Lumina:
I do not know if you have the 2.2L In-Line 4 Cylinder, 3.1L V6, or 3.4L DOHC V6 Engine; however I have included all below.
For the 2.2L (4-Cylinder)
Firing Order:
1-3-4-2
Cylinders:
......(back)
1.....2.....3.....4
......(front)
Ignition Coil Connections:
o <---4
...o <---1
......o <----3
.........o <----2
For the 3.1L V6:
Cylinders:
...(back)
5.............6
3.............4
1.............2
....(front)
.|.1..4.|..|.6..3.|..|.2..5.|
For the 3.4L DOHC V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
.......(back)
1........3.........5
2........4.........6
.......(front)
.|.1..4.|..|.3..6.|..|.2..5.|
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
3helpful
Firing order diagram for a 96 dodge caravan
For the 2.4L:
Firing Order:
1-3-4-2
Cylinders:
1---2---3---4
(front of Van)
Ignition coil:
1----4
2----3
(front of the Van)
For the 3.0L
Firing Order:
1-2-3-4-5-6
Cylinders:
1----3-----5
2----4-----6
(front of Van)
Distributor:
-----2-----1------
3----------------6
-----4-----5-----
(front of Van)
For the 3.3L:
Firing Order:
1-2-3-4-5-6
Cylinder:
1----2----3
4----5----6
(front of Van)
Ignition Coil:
6---3
4---1
2---5
(front of Van)
For the 3.8L:
Firing Order:
1-2-3-4-5-6
Cylinders:
1---3---5
2---4---6
(front of Van)
Ignition Coil:
6---3
4---1
2---5
(front of Van)
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
2helpful
Miss-firing
Your firing order is 1-3-4-2. There are 2 ignition coils under the cover sitting on top of the engine. One coil fires cylinders 1 and 4. The other fires cylinders 2 and 3.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
