Question about Brand Remote Start/keyless/car Alarm Very Sleek
I need to have a copy of the user manual for my SPY 5000m LC113. The alarm was installed by the previous owner and now i have problems using it.\r\n Please help.
  • 123 Answers
The Spy 5000m is a great alarm but difficult to install.
You can get installation and user insttructions from this
site.
http://userguides.50webs.com/spy_5000m.htm
Posted on Feb 07, 2011
SOURCE:
Hi.month ago i install spy 5000 alarm.now the problem is ...cant start the bike because the alarm goes off always
Hi, Georgian read the manual provided in the link below you may need to do an alarm reset for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day
spy 5000m remote start problems ninjette org
How wired my spy 5000m to 2005 kawasaki zx10r
spy5000 alarm manual pdf
2008 2010 Kawasaki Ninja ZX 10R Service Manual Moto Data Project FREE!!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 17, 2016 | 2010 kawasaki Ninja ZX 10R
How do I reset the Master code in DAS NX-4--8 alarm system when the existing Master Code is not known ?
Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
Jun 25, 2014 | Home Security
Beret 2 way 5000m alarm siren problem.
These Alarms are so very fickle. If the Alarm lasted a year, then you are out of warranty and I have removed more than my fair share of Alarm's. As the Vehicle owner, you need to realize that your problem is quite common and you should be grateful it has not complete immobilized your bike. My Recommendation is... Remove it and return it to Stock or spend the money and get a higher quality alarm with a great reputation. Don't truck the Install Shop, they get tied to one brand, find the Alarm that meets YOUR NEEDS...
Mar 03, 2014 | Motorcycles
Hi I recently jump-started my bike (CBR 929RR). Since then I cant turn on the ignition. My SPY 5000m alarm has probably armed itself. The only way to turn the ignition on is to double click remote start...
Might try removing or disconnecting the alarm to see if you have tripped an anti-theft circuit on the bike. If you have then you'll need to refer to your owner manual or local Honda dealer.
If the bike works fine without the alarm then I would reset the alarm. I found the manual on Google pretty quickly
Aug 30, 2017 | Honda CBR 900 RR Fireblade Motorcycles
Have a spy 5000m need batteries where can I find them
In your local shop - a single AAA is all the Spy 5000m remote fob needs.
Nov 13, 2010 | Brand Remote Start/keyless/car Alarm Very...
I need a manual installation guide for a Spy 5000m C1 MODEL
This is the only site I know of that has a manual for the install
and user instructions for this alarm. This alarm is hard to install
but the manual shows you how to do it with diagrams.
Sep 23, 2010 | Brand Remote Start/keyless/car Alarm Very...
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
I dont know where to hook up immobileizer bypass wire
An immobilizer bypass is an electrical circuit which allows current to flow to whatever component is starved of current to keep the engine from running (usually the coil). The immobilizer opens the circuit to the coil, the immobilizer bypass closes the circuit to the coil.
If you didn't install an immobilizer circuit, then you don't need the bypass. There are probably instructions you missed in the manual explaining the immobilizer circuit.
Apr 30, 2009 | Honda Civic Cars & Trucks
Brand Remote Start/keyless/car Alarm Very Sleek Logo
1,482 people viewed this question
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Norman Al-Anbar
Kardoc
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
