Kingston 2GB Secure Digital Memory Card Logo
Posted on Aug 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I put my 2gb Kingston card im my dell windows 7 computer and it says it cannot be found???
Anonymous
Level 2:
Scholar:
  • Expert 179 Answers
  • Posted on Sep 10, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
179
Questions
0
Helped
27756
Points
351
Install proper driver for the card
I have a kingston 2 g flash drive. I put a large number of files from my Dell computer with Vista and the flash works fine on ANOTHER of my computers, a Toshiba Laptop. I put some files on my kingston...
this could be due to the format. i would try different formats on your usb. vista normally reads both but your format may be fat32 which is hit n miss. you can try UDF or FAT. I would format on a vista machine. insert, right click on the drive and select format. you may have to do both with a single file to test reads on both boxes. good luck.
My micro sd card is only making pip sound and i cant see in my computer. i know im suppose to format the SD card after i insert in my computer. i m using windows 7 and cant found sd in my computer please...
Go to Control Panel ' Adminitrative Tools ' Computer Management
In Computer Management find Disk Management, if the card is being recognized at all, then it will show up as a removable disk. Right click on the disk and you can format it.
Jim
I installed Windows 7 on the Dell Optiplex 330, normmally it 's working fine. from last 3 weeks ago, the computer struck and can not do anything.
Windows 7 needs at least 2gbs of memory to work fine and also a good processor.
Where i work we had to buy some memory pents to make this pcs work fine with Windows 7.
if you have a good processor like a Pentium or better you just need to buy memory
i recommend kingston memories, im pretty sure that if you put some memory it will restart to work
fine.
Hope to help you.
Hi When I plug in my memory card,it is not
just follow this link http://www.bioticaindia.com/kingston-data-traveler.html,
Thanks!
I have a new kingston 2gb memory card and im trying to format inside of my motorola slvr 7 and on my dell laptop but i can't for its a failure each time and i even tried inserting a kingston 1 gb memory...
As you want to format the memory card but you are unable to follow the below steps
1. right click on my computer
2. click on manage
3. click on disk management
4. right click on the pen drive option visible in disk management and click on format and click ok
2helpful
2answers
Unable to access CD/2GB due to drivers how can i stall the driver
you do one thing to install dual o.s in your system and solve your problem
2helpful
My 2 GB Kingston memory card is locked. how to open it?
You'll need to reformat the card in order to reset the flash memory.
This is fairly simple to do. Simply insert the card into your card slot and go into My Computer (or just Computer in your start menu, if you're using Windows Vista or 7).
Next, right click on the icon that represents your card (this will be easily recognizable by looking at the capacity of the drive, it should be around 1.6-1.8 GB) and select "Format...". Format your drive using the recommended settings (usually FAT32, Quick Format) and you should be able to access it.
How to upload pictures by my usb
That really is a matter of if when plugged in to the USB port of the computer you are using, if computer you are using can recognize the drive.
If you are using Windows XP, check "My Computer" and you should see the Kingston USB jump drive showing as an device icon.
In Vista and Windows 7 select "Computer" and you should also see the USB jump drive listed as a device icon.
If you are using a Mac OS X computer with your Kingston jump drive, providing the drive has been formatted with the Mac OS Extended (Journaled) format, or the MS-DOS format (which is readable on both Mac and PC platforms), it will show up
in the Finder sidebar and on your Desktop.
Either platform however, to load pictures onto your Kingston is easy, all you have to do is either copy the pictures from there respective folder or location and either right click on the Kingston 2GB HD icon and paste the pictures.
Or you can double click on the Kingston 2GB USB icon and paste or drag the pictures into the open window of the Kingston 2GB USB jump drive.
That is honestly as simple as it is.
Now, on the other hand, here are a few steps, if you want to upload to an online resource which allows photo uploads from another source, namely your computer..
When you use the upload feature of that website or webpage to upload your pictures to, no matter whether you are on a Mac or PC, you simply have to click that uploader's Browse or Upload button.
Next, simply locate the Kingston 2GB USB jump drive in My Computer, (Windows XP), Computer (Vista , Win 7) or Devices and/or Desktop (Mac OS X).
Then start selecting and uploading your pictures onto that website or webpage with your Kingston as the source drive.
Yes, I have given you a number of options, but hopefully you will see the ease of using any of these methods, again depending on what computer operating system you are using, how easy it is to upload photos from your Kingston (DTIU3/2GB) 2 GB USB Hard Drive.
Regards,
-Mactechtrainer
Can't put music on my microsd card from my windows media player
i can't put music on my micro sd card from my windows or on my pc.
3helpful
2answers
Cannot read Kingston 2GB SD card on my computer
Dear,
All just try this trick
Connect your phone to PC and try to acces the card on PC. Now format the card but, take the backup of data before formatting the card.
Regards,
Rakesh Kumar
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
