First check the power cord and source.. if you have a spare cord, switch them, if this does not work turn on the printer and listen closely for any sounds, like a humming , if there is not sound then there is a fuse on the power supply, you can pull it and replace.
and if that does not solve the problem time to replace the power supply board.
If you need further help, reach me via phone at https://www.6ya.com/expert/howard_563901c2e8628759
After such an event, normal operation should return within 15 minutes.
If the No Power condition persists:
Make sure the printer is plugged into a functioning wall outlet supplying the proper voltage (110V or 220V).
If you are using a surge protector, extension cable, or power strip, plug the printer directly into the wall outlet.
Press the power button to turn on the printer.
If the issue persists, unplug the printer and wait 15 minutes.
After 15 minutes, plug the printer back in and press the power button.
If the issue persists, try a different power cord (if available).
Regards,
Rachel Gomez
