Question about Mitsubishi WS-55511 55" Rear Projection Television
WS-55511 shut itself down while watching TV and won't come back on again. I tried unplugging and reconnecting, it goes through the reset (green light blinking). The convergence went bad and the chip was replaced couple of months back. The tech had mentioned that the voltage output from tubes are low and the TV may shutdown or something along that lines. Looks like this is what is happening. Replacing tubes are not an option for me. Any other options to consider?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
After you turn on and green power light comes on and then goes out:
Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it 4 more times.
Let me know what error code and I will tell you what it means. If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 23, 2010
Testimonial: "The lights flashed as follows - 1 blink pause 2 blinks pause 1 blink pause 2 blinks and so on.. total five sets of 1 blink pause 2 blinks pause"
  • 4 more comments
  • Ajoy Cherian Aug 24, 2010
    The error code was as follows - 1 blink pause 2 blinks pause 1 blink pause 2 blinks and so on.. total five sets of 1 blink pause 2 blinks pause
  • SD Tech
    SD Tech Aug 24, 2010
    1,2 BLINKS IS OF COURSE NO ERROR DETECTED. it means something is not triggering the error code--a lot of possible reasons for this.
    Unplug set, plug back and try it again--if you unplugged it before trying the test you will get 1,2--try again and let me know what it is.
    SD TECH
    Tried that, it's the same sequence 1, 2. The TV is about 7 years old. As mentioned in the original post the tech who replaced the convergence IC did mention the tubes are dying and the TV will shutdown. Any idea how many hours these tubes/TV last? In my estimate, the TV has been used heavily - probably about 35,000 hours in the last 7 years
  • SD Tech
    hours do not matter with these sets, if the tubes were the problem you would have different code.
    You have Yahoo Instant message?
    SD TECH
    I have a Yahoo ID, but not used the IM on that but I think it should work since I have a yahoo id
  • mapcg18 Sep 14, 2010
    SD Tech i need help also!! i have the same type of tv and the screen just "shuts down" then comes back on. after it has been on for a while and the green light stays on the entire time. i've tried to check the error code and it is 1,2. please help thanks
SOURCE:
GET DIAGNOSTIC CODES
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
Oct 29, 2012 | Mitsubishi WS-55511 55" Rear Projection...
When I attempt to turn on the TV the green power light will stay on for about 2 seconds. Did system reset with paperclip, timer light flashed for 1 minute. Tried again with same result.
STANDARD ANSWER FOR THIS PROBLEM:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
BEFORE YOU RATE THIS INFORMATION LET ME KNOW WHAT YOU FIND, i AM HERE TOP HELP.
SD TECH
Jul 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a mitsubishi model WS-55511. The green light keeps blinking. Have reset by unpluging and then pluging back in and holding the reset but for 5 seconds and press the power button. worked once, but...
TWO possible reasons for the blinking light:
1. The DM unit (caps and or fuses) are bad---no longer made and only (to my knowledge) PTS electronics repairs/rebuilds them.
2. Less likely but Possible: remove front speaker grill and inspection plate behind it----locate the two bundles of wires from front keyboard on set and follow them down and to the right---unplug both plugs and plug set in and wait 70 plus seconds and try to turn set on with Mitsubishi remote.
The blinking light is the DM trying to boot up--if set works with front keyboard unplugged---the tiny reset switch on it is bad.
If set does NOT work that way DM UNIT IS BAD.
SD TECH
May 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Won't turn on after reset ws-55511 hdtv
YOU GOTTA REPLCE THE STK ICS OR THE CAPS ON THE DM BOARD
Jul 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 Problem TV out - Getting only continously blinking green light on the front-panel
I had the same problem with the blinking light on the front of the TV and it would not power up. I read all the problems everyone was having and thought I was going to face a huge repair bill. The service guy came out, pulled off the front panel where the speakers are and disconnected the circuit for the front display panel. 3 1/2 minutes in my house, $90 service call. Apparently, when you give the TV too many commands at once, it's safety feature is to"shut down and lock up". He mentioned also that sometimes when these sets get to be about 4-5 years old, the wires in front can "leak" causing a shortage and then locking up the TV. I keep the circuit unplugged and operate the TV solely by the remote. Give it a try, what can it hurt!! Hope this helps.
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi
i just sent the response to your email address
Sep 16, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
307 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
