Watches Logo
Posted on Aug 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you get the back off for new batt - Raymond Weil Watches
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 24, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
457739
Points
2634
Replacing a Raymond Weil watch battery should be performed by an authorized Raymond Weil dealer. Replacing the battery on contemporary Raymond Weils takes some skill because the case is pressurized on some models or contains a rubber gasket to keep it water-tight. If you determine your Raymond Weil watch has a pressurized case back, don't attempt a battery replacement. Take it to an authorized dealer. The warranty on a recently purchased Raymond Weil watch will be voided if you perform a battery replacement yourself. Replacing the battery yourself on older Raymond Weils without a warranty is an acceptable risk.
2answers
I have a black fossil watch that needs a new battery. On the back, it has the letters and numbers of FS 4605 251203. It also has All Stainless Steel 5 ATM. Please advise.
try this video and get the battery out. Then you can fins the number on the batt and get it from shop or Amazon. https://youtu.be/r-zl5CTKT5I
TGXL103GRN
TGXL103GRN Check inside watch where the battery holding area has a metal tab to secure it. There's always a big gap btwn the tab/batt area and where it makes keyboard contact. To fix:
1 remove screws and watch back.
2 put tiny screws in dish
3 notice battery condition/position.
4 change batt if necessary
5 fold a tiny piece of paper to fill gap
6 use tweezer to put in place (no foil, no glue)
7 to test if gap is gone, close watch
8 must screw shut + reset to test
9 be patient, adjust as needed
10 take care to not strip screws.
Jan 26, 2013 • Watches
Wen i press the light button the watch screen dissapears
I'm sure it is low batt.. replace a new battery and it works properly again.. i'm happy that i have been help you..
What type of battery does an ebel (feman) watch use?
ebel keeps that a secret they have a marking on there batteries mine 690 but there is no such after market replacement with this number. ( ebel wants to be the only game in town/ world ) but if you want to replace it your self, witch will void your warrenty 'says' ebel. take the battery out and take it to a jewelry store, and they can match it up ( $5.00 to $6.00 ) or pay $240.00 to ebel to "service" it. clean / new gaskel / batt witch ebel says is necessary to change batt. every 3 years or so. do not take the watch to the jewelery store only the battery , because know one will open it. they will want to send it out to ebel for service big $ also save old batt, because if you ever have to have the watch fixed put the old batt back in and hopefuly they wont notice. to get the battery out read my instructions i have posted its easy. other posts i have read on replacing batt, they don't know what they are talking about. do NOT remove anything but the bezel only. please Read hope this helps you out.
Purchased a new pulsar chrono as a gift, the battery was dead, since found out low charge batteries are placed in new watches to check functions but they recommend the battery be change. Problem is,...
I would return it sounds not like a batt. problem but internal mechanical. If you have a reciept dont deal with a potential problem get a replacement.
5helpful
BAtt flashing on digital screen although I only
Yes, the flashing battery icon tells you it's time to change the battery.
Despite of that the watches are fitted with brand new batteries when they are leaving manufacturer, there can be a significant period of time till they reach their new owners and the watch battery can be flat (or allmost flat) at the selling point.
I suggest you visit sellers shop again a.s.a.p. and ask for the brand new battery to be fitted under the warranty.
Rate me, please.
14helpful
3answers
Ebel Wave lady's watch battery
to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
17helpful
5answers
I have a Casio CPW-310-1VDS watch. Is there a special procedure to change its battery? This is watch has the ability to notify the wearer of the times for prayer (a popular model worn by Muslims) and also...
Guys, I just realised that there is a mark called AC on the back of the module next to a gold small circle pad. Once you change the battery, you need to connect a wire or paperclip or something similar between the back or positive of the battery and the pad, it should then come alive. Good luck
Apr 26, 2008 • Watches
Top Raymond Weil Watches Experts
ADMIN Andrew
ADMIN Andrew
Rogaciani Ogwang
Rogaciani Ogwang
Are you a Raymond Weil Watch Expert? Answer questions, earn points and help others
