Make sure you ALWAYS RAISE the presser foot when threading the top thread. This helps seat the thread in the tension disk.
Ls 1217 tention knob is stuck can't turn left or right
You should be able to fix this. IF it is the top thread on your fabric that is screwy you need to adjust the bobbin tension.
If it is the bottom thread you have a problem with your upper tension. Blow out the upper tension assembly using canned air, the tension discs may be dirty
