Pride Mobility Products Jazzy 1103 Ultra Electric Wheelchair with Powered Seat Lift by Pride Mobili Logo
Posted on Aug 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Pride wheelchair. I have taken the chair apart and cannot find a model number on the outside or inside. I can only find a tag with a lot of numbers on it, but nothing that starts with a "J". What can I do to get the model number?
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Aug 25, 2010
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288846
Points
1801
The serial number is on the tag with a lot of numbers. Those are the serial numbers. the model is Jazzy 1103 Ultra. Hope this helps
How can I get this chair to work
Pride Mobility Products Download the trouble shooting information for your model chair.
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
2answers
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
I can't get the chair back on, the pins won't go thru the posts, holes don't line up
These are made pretty rigid so you are going to have to go back and see what part you have in backwards or the wrong order. An example would be washers that need to go on the inside instead of the outside.
1helpful
2answers
Install foot rest
If you have the swing on footrests or legrests for a Pride Jazzy series with 2-pins on the hanger brackets please be sure that the hanger brackets are properly installed on the chair with the pin side of the bracket facing to the outside - not inside. To put the footrests on - align the lower pin first with the footrest at a 45 degree angle to the outside of the chair. Then align up the top pin and lower the footrest onto the hanger bracket. Rotate the footrest towards the front and lock the cam lock in place. If the cam lock has a handle that is bent it will interfere with the lock and need to be replaced or bent back in place.
Pride z-chair vsi controller battery condition lights don't turn off
they wont as long as its turned on, sounds like he is fishing,and is not qualified or he would have a programmer for that chair and he could check error codes and tell u exactly what is wrong,call the dealer for a more exsperienced tech and give model of chair and request he have a programmer for that model power chair okif he comes without that ptogrammer send him back and dont pay him
I have a jazzy 14 new is there a way to program it to travel faster outside the house like going to the store etc,??
Pride chairs can be programed. But u must contact your local dealer you bought it from. Only they can do it or refer you to a ful service Dealer who can.
What kind of Jazzy select 6 power chair does my Mom have? Serial number J92037090688C30. We live far away from each other and I need to know what she got.
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
