Maytag MSD2651 HE Side by Side Refrigerator Logo
Posted on Aug 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker will not work. Water is coming into the back of the refrigerator and water dispenses out of water dispenser. But no water will go to the ice maker.
Charles T Nevin
Level 3:
  • Master 4,070 Answers
  • Posted on Aug 23, 2010
Charles T Nevin
Master
Level 3:
Answers
4070
Questions
0
Helped
1088063
Points
13055
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Ice dispenser on refrigerator has quit dispensing. ice maker and water dispenser still work. fuse, switch? What do I need to do?
https://www.youtube.com/watch?v=p9GjSqi6eY4
https://www.google.com/search?source=hp&ei=yj52Xrn4O9aGjLsPjY2MkAY&q=Ice+dispenser+on+refrigerator+has+quit+dispensing.+ice+maker+and+water+dispenser+still+work.+fuse%2C+switch%3F+What+do+I+need+to+do%3F&oq=Ice+dispenser+on+refrigerator+has+quit+dispensing.+ice+maker+and+water+dispenser+still+work.+fuse%2C+switch%3F+What+do+I+need+to+do%3F&gs_l=psy-ab.3..0i362i308i154i357l6.3892.3892..4963...0.0..0.280.280.2-1......0....2j1..gws-wiz.....6.KpTP5CQ-W1Y&ved=0ahUKEwi5hZO9_KvoAhVWA2MBHY0GA2IQ4dUDCAU&uact=5#kpvalbx=_8UF2Xqv7BqLHxgOu8YKYDw57
3helpful
2answers
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
A strainer before the inlet valve can also get stopped up restricting flow.
Ice maker works but water dispenser stopped working
There sould be a set of water control valves on rear of refrigerator and where the water comes into refrigerator dispenser and ice maker. When one goes bad you replace both. You can test the windings in each coil or test for voltage while someone presses dispense water.I will ty to locate one set with your model number. Sea Breeze
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
1helpful
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
2answers
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
2answers
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
2helpful
Ice maker issues
Replace the Motor Module on the ice maker. I had the exact same issue.
7helpful
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
